Front seat bolt size
v guy
Syracuse
RP
99 SVT
The 2021 Mach 1 uses 4, T-55 headed bolts, to mount the front seats to the floor pan.......bolts are about 1" long
Does anyone know the thread pitch?
I find no facts regarding these bolts, and replacing them with longer bolts, in the rear set of holes.
Reason:
I want to mount a CMS seat belt harness bar, to the front seat's, rear seat mount holes....the stock 1" bolts sit in a recess, and are likely too short to mount the bar, without a longer stud, and spacer for the recess.
Has anyone actually mounted a Watson, or CMS type harness bar?
With much research, nothing here........ I finally found how the front seat's, popcorn catcher flap, attaches to the seat bottom--the flap has two long elastic straps, mounted under 2 electrical connectors, holding them in place.
I needed to know that , as I want to attach sub straps to the CMS bar without cutting a slot in the flaps.
thanks in advance , for the bolt info, if it is known.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
You will need the T50 to remove the OEM bolts anyway, so why not just pull one of the fronts to check the thread spec yourself?
v guy
Syracuse
RP
99 SVT
I am going to do just that.
In the meantime, and I had missed it........ CMS recommends mounting the harness bars, UNDER the seat rails/platform; sandwiching the plate under the seat.
I will still determine the bolt thread size, and post it.
Mach1man
New York City
Brian
2021 Mach 1 2001 Bullitt Mustang 2001 GT Mustang
I ran into the same problem when trying to install a Watson harness lap belt mount. I removed rear bolts, sliped mount under seat rails. Then found bolts came up short. I spent 2 weeks trying find longed bolts, no luck. Then the lights came on I removed both front seat bolts. Allowing me to tilt seat back just enough to catch rear threads. Give it a try
https://shop.watsonracing.com/HARNESS-LAP-BELT-MOUNT-p/wr-harnessmnt.htm?CartID=1
v guy
Syracuse
RP
99 SVT
Ok,
Stock rear seat bolt is:
10mm x 1.50 pitch 1.2" long, or 30.45mm long.
I purchased 2, 10mm x 1.50 pitch 42.54 mm length. Looks like it will accommodate the Watson 1/4 plate, as it measures about 12MM 1/2" longer, but needs a 1/8 " washer under the hex head to spread the load.
The 1/8" thick CMS plate...I I got two 37.46 long 10mm x 1.50 pitch bolts. Looks like it will be enough.
Fastenal
WD Pro
United Kingdom
Lime GT
