TonyNJ
- Jul 14, 2021
- Northern NJ
- Website
- www.instagram.com
- Tony
- 22 GT500HE Black Stripes, 20 GT350HE, 16 GT350R Ba
I'm sorry. I didn't explain better. The sound in the video isn't the sound I'm hearing when I'm turning hard locked left. It's just a comparison between two cars that have, and don't have the issue you're describing. It's almost impossible to record the sound when the car is running and I'm pulling forward slowly to produce the "floorboard clunk at hard left". What I'm suggesting is that a worn steering rack could be causing that anomaly. As these cars have electric assist steering, the worn out internals could be clunking under left turn lock. I may replace that rack. I'll let you know if it's clears the clunking.That is a whole different issue then what is being discussed, that could very well be something else or loosening of the u joint or some give, I will make a video of my sound, which is the same as another member here did which only occurs when hard locked left, the motion of moving it slightly back and forth does not create this issue like you have, yours clearly is a steering rack issue.
