ForScan question - line level inputs
tcclindy
Raleigh, NC
Krazy
2015 Mustang GTPP
I read the ForScan thread, just trying to confirm these code give a FLAT/LOW level signal I can run to a TwK-88 and/or my amp. Trying to avoid having to buy the Fix-86 to flatten everything out if ForScan can do it for free.
727-01-01 xx5A xxxx xxxx
727-01-02 00xx
Anyone who is using a TwK-88 any input would be appreciated.
Thanks.
tcclindy
tcclindy
Raleigh, NC
Krazy
2015 Mustang GTPP
D
727-01-02 00xx
Thanks.
Does any know if these codes are correct, I am searching in ForScan and cannot find any 727-* codes when I read, I have looked under every module does any one know where to find them. I am running 2015 Mustang GTPP, is it possible that my whipple tune wiped them?
Thoughts?
Cathul
Germany
Peter
Ford Mach-E
If your Whipple tune wiped them you would have no radio anymore.
You sure that your OBD adapter is able to handle both MS-CAN and HS-CAN messages?
Hykr3n
Quebec
Mustang gt2017
Remember reading somewhere that forscan can't read on tuned car.
Have you tried going back to stock tune to see i you can set you low level output and then re install whipple tune?
SpArKy
Eaton Bray, UK
Mustang GT
nah, forscan can read and write tuned cars no problem.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
D
Thoughts?
Does your ODB programmer have the MS/HS toggle switch on it? Forscan will ask you to flip the switch to read all the modules. The module with 727- is called the ACM.
tcclindy
tcclindy
Raleigh, NC
Krazy
2015 Mustang GTPP
Bought an ODBLink MX+ worked like a charm, signal coming through is perfect.
