Everyone has this problem. You have to cut to fit. Sad but true. There are some videos out there. I believe CJ Pony had a decent one.Just received my EBM Procal kit. Very disappointed in fit of air inlet. after modifying (cutting inlet tube seal), and comparing old inlet to new, I discovered that the new inlet is smaller than the one it's replacing. The new one does not fit over the the in place air nozzle. So now I have a inlet tube that is not sealed properly installed.
Has anyone else noticed this problem while doing the air bucket install? I'm having a feeling I didn't the EBM inlet but the GT350 in it's place.
Anyone have this problem?
__________________
I'll look into that app for sure. I don't mind paying what I do, but if I can find it cheaper and it still be a good brand, then sign me up.Regular (87) is $1.95/gallon here while Premium (93) is $2.57/gallon. I run Premium in my EcoBoost vehicles and run Regular in the Mazdarati (daily).
200 miles? I don't believe that.... either they did not understand the question or you did not understand the reply.Just an fyi for those wanting to switch octane frequently I sould suggest not doing so. FP specifically told me downgrading octane will force the PCM to relearn the new lower octane and of course timing will be pulled during that process (which should be obvious). Also you cannot go from 91/93 to 87 regularly, in an emergency you can but your limited to ver light throttle and keeping rpm up while accelerating to prevent knock. It takes 200 miles for just 1 drive cycle and can take several drive cycles to fully optamize depending on conditions etc..
I'm curious to know what you learn as well. Because when I bought my car the very first tank from the dealer was on 87 octane. I ran it about 150 miles then I did a couple of tests with the track app. Did a 0-60 and a 1/4 mile run. 0-60 was 6.0 seconds and the 1/4 mile was 14.4 at 96mph (now I did not realize the car was on 87 at that time). When I filled in my 2nd tank on my own I put in 93. I maybe drove 15 miles or so and then did a test run again. The car then did 0-60 in 5.6 seconds and the 1/4 mile was 14 flat at 100.200 miles? I don't believe that.... either they did not understand the question or you did not understand the reply.
I'll ask after the holidays... but since you seem to have a "red phone" directly with Ford performance, maybe your reply will be faster (they did not reply back to me the last time I emailed them on clarification on a question).
Timing can scale depending on knock within a particular table set. However when the PCM is finding it's constantly using the most aggressive values in the table and no detectable knock it will incrementally advance to the next set of tables until it reaches safe limits.200 miles? I don't believe that.... either they did not understand the question or you did not understand the reply.
It's entirely possible drive cycle is based on a complete collection of specific data and not mileage, I've never had a chance to actually look at the compiler code for a PCM. Perhaps the 200 miles came from the general assumption that's the average time it takes to get all of those parameters / data? I don't know, all I can provide is what I've gathered from my FP contact.I just talked to FP and as I've said before, there is no mileage for the tune to "kick in" or complete a drive cycle by mileage. FP says what they were trying to say is just go drive the car and have fun. They said the reference to 200 miles was a loose reference meaning just drive it for a bit and don't think about it. I mean if you've ever looked at the tables in a ECU, have you ever seen any table that counts miles? There isn't one.
There is only one learning cycle other than normal driving and that is to do 3-4 pulls at about 50% throttle from 50-75 MPH. That is only because this is the first time they have enabled the learning for 87 octane to be used. All of the tables need to be relearned and for the other tables, it's no different than if you disconnect your battery for 10 minutes then reconnect it.
At any rate, I also found this on the warranty information since there was so much debate on that:The octane modifier learn funcon will be learned over the course of a few hundred miles but it can be learned
more quickly by performing 3 to 5 moderate acceleraons. Accelerate from 50-75mph in 4 gear with 50%
thro8le.
If you ran 93 octane in your car consistently before our calibraon was installed, it probably was opmized for the
higher octane. Installing our calibraon essenally returns to a baseline for the PCM and it must relearn to
opmize for the premium fuel. Timing will be retarded unl premium fuel is learned by the new calibraon. It
does take me for the ming to be opmized for premium fuel to make the maximum power.
Hope this helps.
Mike Goodwin
[email protected]
(800) FORD-788
www.fordshowparts.com
www.fordperformance.com
www.performanceparts.ford.com
The language is pretty clear, your original new vehicle warranty is still intact, including the 60k miles for power-train / 36k bumper to bumper UNLESS the failure is found to be related to the Ford Performance Parts / Upgrades.Installation of these select Ford Performance and mountune warranted performance packs and
components by an authorized installer will NOT void your New Vehicle Limited Warranty. Engine, driveline
and suspension concerns not caused by the use of Ford Performance or mountune parts remain eligible for
warranty coverage according to the terms of the New Vehicle Limited Warranty.
Ford Performance and mountune parts are aftermarket parts. The use of Ford Performance and mountune
parts may impact the performance characteristics of other systems of the vehicle. Even when operating properly,
Ford Performance and mountune parts, such as these, have the potential to adversely impact other systems of
the vehicle. If an adverse impact is caused by a warranted Ford Performance or mountune performance pack or
component, the period and coverage of this Ford Performance Limited Warranty applies to the repairs.
Completely agree, I think we're still learning. Seems like a lot of people would have been in that area when there engines blew. I know a couple people said they were just merging on to the highway. figuring most highways are 55-75 MPH, it is very reasonable to think they were accelerating in that range.It's entirely possible drive cycle is based on a complete collection of specific data and not mileage, I've never had a chance to actually look at the compiler code for a PCM. Perhaps the 200 miles came from the general assumption that's the average time it takes to get all of those parameters / data? I don't know, all I can provide is what I've gathered from my FP contact.
What ever the case, it does take time to learn the octane and it seems mine did take several hundred miles of driving to get to the point its at now. At the very least we know you need to drive it for a while and it would be good to perform at least 3-5 pulls at 50% throttle from 50 to 75 mph during that time to speed up the octane learning process. It is my understanding that is where the greatest knock will occur, is actually at partial throttle and that's why. Coincidentally that's where 90% of engine failures seem to occur, during normal driving (2k to 4k rpm, intermediate loads like merging onto highways) not WOT, at least when I spend a multitude of hours looking at failed Ecoboost engines of all sizes and flavors to see what the common causes were likely to be.
I'm not saying I disagree with what you are saying here but think the way you're interpreting it is misleading. Now that you've read that, it would probably help if you read the Ford warranty and read it from their perspective. I referenced the section a while back but basically Ford says (loose translation, not a quote) if you modify your vehicle with aftermarket parts, they will not cover damage that may have come as a result of that upgrade.At any rate, I also found this on the warranty information since there was so much debate on that:
In that case your covered up to 36k or 3 years for failures specifically related to the upgrades. I have a hard time imagining if your fuel pump fails or a cam bolt shears off for example they could blame that on the Ford Performance parts without some convincing evidence, you can bet FP will be on that claim as they are on the line for the bill which Ford would otherwise be. And yes, FP is a different company than Ford. They work alongside Ford as a performance division but are their own entity.
In that case it would still be covered under warranty. However it would unfortunately be more difficult if not impossible to do so with another tune...that was one of my reasons for using the Ford Racing X Street springs, hard to blame alignment problems on lowering springs if their Ford's own. There might be more merits to keeping the FP tune on your car for more than 36k, you might be better off leaving it on until you hit 60k. There's a lot of merit to repairs still being covered by Ford up to 60k / 6 years even though they only cover failures found to be directly related to their modifications for 36k / 3y.
FP also stated (for forget where, but it was one of their PR articles about the Ecoboost PP on FP's site) after 60k miles they did not find any abnormal wear over that of a factory EB mustang, so maybe that sheds some more light onto a statement like that. Now the real question is, how fast can these EB's sprint down the 1/4 with just bolt ons?
https://performanceparts.ford.com/warranty/include/pdf/Select_Parts_Warranty_Statement_2015.pdf
