Ford Performance Tune for 2018+ GT
WD Pro
United Kingdom
Lime GT
Don’t wait, just shift and all will be smooth. Unless our euros are programmed differently … ?
WD :like:
bigmixx
Georgia
2020 GT Premium PP2
WD :like:
Could be. On the stock tune the revs drop way too slow and there is almost always a rough 1-2-3 shift.
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1 6MT Rapid Red
There is a bit of rev hang still after WOT runs, but its very diminished vs. the stock software.
spaz mk will
Indianapolis, Indiana
Will
2018 GT
Yes I’ve noticed this as well. Makes me wonder if the strategy is to prefer rpm to be a little high vs a little low on upshift in the case the car is being wound out through gears. I will ignorantly speculate as to why: I think it makes more sense to slow the engine a little at mesh vs accelerating it with respect to fuel and timing controls. Well outside my expertise though.
Dave2013M3
El Segundo,Ca
Its a cat protection feature.
bigmixx
Georgia
2020 GT Premium PP2
You might be on to something though. Because the shift is only smooth when the engine speed slows. Either that or the GT350 throttle body helps with with throttle response which resolves the rough shifting. Because whether you shift early in the rpm range or take it to near redline it usually results in a rough shift if you don't wait until the engine speed slows a bit before getting back on it.
spaz mk will
Will
2018 GT
Dave2013M3
El Segundo,Ca
Oh interesting. Care to elaborate or point me somewhere? I’m curious how that’s related.
Thats what Ford Racing told me...I was a little disappointed that it was still there, not as bad as the OEM software but still there. I will see if I can find the email. They also said its part of keeping the emissions at bay for the CARB EO# as it helps burn off unburned fuel still in the intake.
spaz mk will
Will
2018 GT
That could also be a result of engine and wheel speed not being matched at the moment you get back on throttle. I do that plenty when I’m winding it out and shifting aggressively at redline, still a skill I don’t have mastered.
spaz mk will
Will
2018 GT
Turns out it’s easy enough to find something related online. Here’s a blog post copying an interview from Autoweek. I got about 5 search hits all with the same wording 😂 It covers VW emissions with manuals and how rev hang can avoid lean air/fuel conditions and reduce NOx.
https://canadaconnexions.com/vw-uses-engine-rev-hang-to-cut-emissions/
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Rev hang explained:
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
There is a setting that can be toggled in the ECM to turn rev hang on/off if I am reading it correctly....
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
What are you using to see that?
spaz mk will
Will
2018 GT
Mach VII
Berkshire Hills, MA
HP Tuners. It is from my Ford Performance tune file, I would have to dig deeper to see if any parameters can be changed...
