Ford Battery Management???
fcarpio
South Florida
2016 Mustang GT PP
I was in another forum (not car related) and I was told that I can only get the FoMoCo battery as a replacement because of the Ford battery management system in the car. Is this the case? That sounds weird. Anyway, if that is not the case, which is a high quality battery I can get for the S550 GT? What are you guys/gals using?
Are you in need of a replacement battery in a 2016?
If so, Warranty it - you’ll get a free battery from Ford... then if you want an aftermarket or other as a replacement over that stock battery - sell off your “new/free” battery to offset the out of pocket costs needed for the aftermarket.
Rasn1320
PA
Jer
2017 GT premium 5.0 black accent pack, 3.55 gears
Interstate used to be good. All the shops ive worked at they last about 2 yearsish. Ive had alot of luck with exide. Motorcraft batteries are also good.
