Flat Spot Tire FEELING
MidnightStars
North PA
When creeping forward, up to maybe 5 mph, and when braking and reaching less than 10 mph, the car feels like it has a flat spotted tire.
This has been present even before I changed out my tires + wheels, and confirmed that my new sets were in FLAWLESS condition. Feeling remained the same. Does anyone have any idea what it is?
At this point in time, I know my lower control arms are worn out & need to be replaced (59,000 miles). However, when at Ford during my oil change, I had them look into the issue, and they couldn't find any problems that could cause that "flat spot" feeling. As of now, the car's wheels and tires are still perfectly round. I haven't quite heard of worn control arms creating a feeling like this though, so I'm doubting it's just that.
Thanks!
compprep
Central, New York
Jim
19 GT PP1, 86 SVO, 24 S5, 74 MGB GT
Brake rotors warped? Or a spot on rotor that pads catch differently vs rest of rotor?
MidnightStars
MidnightStars
North PA
Had that thought at first, but it occurs when starting from a stop--foot off the brake, no gas. Wish I could record it, but it's visually undetectable within the car.
IPOGT
Alan
How do the wheel bearings look? At 59k I’d be looking at that.
MidnightStars
MidnightStars
North PA
Hehe, how do I check it? Lift the car up and feel for inconsistent resistance within itself, plus on the opposite side, by rotating the wheel?
IPOGT
Alan
I’d go to a tech you trust, but highly suspect at 59K. But if you spin it in the air it should tell you something, but I’ve seen them seem good until weight is on them…all scored up.
MidnightStars
MidnightStars
North PA
Sadly haven't found anyone yet--moved in the past year, and not quite sure who to look into yet. Probably will hit Ford first, but I bet I will be hit with crazy labor charges or long waits 😭
compprep
Central, New York
Jim
Make a new thread asking if anyone here has a suggested shop near you. Note: state where you live and how far willing to travel.
IPOGT
Alan
Probably not for that. It’s routine stuff they should have enough techs for that. Not trans work. At least it’ll be fixed correctly. Maybe checkout Discount Tire they’re a sponsor and maybe they do front end work.
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
In my experience I ve never felt flat spots at that low of speed. don t think that s it , you d feel it up at higher speeds even more IMO.
MidnightStars
MidnightStars
North PA
Good idea--I should have thought of that :crazy:
Gotcha! And really? I thought Discount Tire only handles... well, tires!
Yup, the other reasoning I knew it couldn't be that. But it's the closest thing I could think of that gives the feeling.
JustSomeGuy
JustSomePlace
JustSomeGuy
Mustang GT
Fixed correctly? At a Ford dealership?
The only thing I’ve ever brought my car to a dealership for was a rear wheel only alignment and all I got was my front wheels OUT of alignment. Dealerships are horrible.
MidnightStars
MidnightStars
North PA
Russell & Smith in Houston were great to me. But I have a feeling that the Roger's Ford here is going to be a little sus.
IPOGT
Alan
Lucky here. My main servicing dealer is generally very good.. Could even be a warped rotor.
Discount Tire
Arizona
discountti.re
All Things FORD
@MidnightStars While your local Discount Tire store does not do mechanical work, they may be able to help with a diagnosis. A thorough road test might be able to determine where to focus your search for answers.
The first thing I am going to look for is drive train or tire/wheel assembly issues. Eliminating one of the two will put you on the right path to a solution.
Your local Discount Tire store will do that diagnosis at no charge. Feel free to stop by. No appointment is necessary.
