First MOT
v8hgt
Cheshire, UK
Nick
Race Red GT PP Coupe
Yesterday my mustang passed its first MOT with flying colours. The emissions were spot on, despite the gt350 IM and aftermarket tune which I was a little concerned about.
I hear that some cars running aftermarket cats have been failing on emissions recently, which brings me onto my next question. Has anyone passed emissions with non standard cats? If so can you post the type of cat? E.g kooks green etc?
Would suggest not posting any details if you passed an mot at anywhere “specialist”... stick to 100% above board places.
GR11M
Herts, England
Graham
Ford Mustang GT
I'm running Kooks rhd 1 7/8" long tube headers with green high flow cats and mine passed.
marks
Essex
2017 Mustang GT Race Red Manual
Another reason to keep your original cat back in the garage and not use an axle back! Any issues then 5 min job to replace.
GR11M
Herts, England
Graham
Ford Mustang GT
When I had the headers and cats fitted I had the garage run an emissions test so I knew they would be ok.
SpArKy
Eaton Bray, UK
Mustang GT
I'd love to see someone change an exhaust in 5 minutes, takes me longer than that to find my axle stands :cwl:
v8hgt
v8hgt
Cheshire, UK
Nick
Thanks. Good to hear kooks greens pass our mot standards. As I suspected it makes sense to spend a bit more on the cats
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
200cel + should pass.
Under 200, get that thing red hot it'll pass....(maybe).
FWIW my 200cel passed first try
hinch
uk
Sideways
enoch's failed he's got 200 cell greens i believe. i ..... passed :lipssealed:
Supersolo
Northamptonshire
2019 Ford Mustang GT
Excatly my thoughts. I read Enoch's comment on MoT then went & looked at his videos related to the install of LTH & IIRC 200 cell cats.
So now I'm totally confused by conflicting claims about what exhaust modifications will pass the test :facepalm:
v8hgt
v8hgt
Cheshire, UK
Nick
Are all 200cell cats created equal?ie does 200cell refer to the size of the pours an not the length ?
Just asking as I would love to fit headers at some point but not at the expense of it being ‘harder’ to pass an mot as they are closing the loopholes all the time
Entai
Bedfordshire
2019 GT kona Blue, A10, Magneride, CP 2. Daily Driver
It determines the number of cells per square inch of substrate, most pure race/track cats are 100 cell, as road emmsiions specs are not needed to be complied with.
But if you need to go on road, or be in a competition where a pass on road legal emissions tests is required then 200 cell are recommended.
In a sports cat the substrate is usually a stainless steel, instead of majority of road cars where the substrate is a 400 to 600 cpsi ceramic that is very susceptible to vibrations and excess heat damage, the sports cats are far more durable as made from steel.
Basically it is always advisable to get the biggest catalytic converter you can. By biggest I mean diameter of the cat, be it 4", 5" or 6", different manufacturers can supply larger or smaller depending upon need.
The larger the cat means lower back pressure, but mainly more surface area of the substrate, therefore it will have more chance to get the emissions within spec.
christianUK
Sussex
Christian
GT auto
Off to the family friend garage for mine in March
Manders Mustang
The Boss
