apx632
- Jan 20, 2016
- The Woodlands, TX
- 2016 Ecoboost Mustang Stock- 13.64@100 1/4 mile
I would be willing to be you Livernois increases boost in their tune. Stock the cars are peaking somewhere between 18-20psi. On a tune I bet Livernois increases boost to 22psi peak and ignition timing. I can tell you I logged my Cobb Tune vs my Tune + tune (both on 93) and saw the vast differences. As far as OAR, the gas in your area must flat suck because my OAR has never strayed away from -1.00 on any of my tunes.Your presume too much and I think we went around this circle before (you and I that is), Livernois doesn't increase boost, nor does FP. They achieve their results via other means. Remember there's more than one way to skin a cat.
I've found forum posts, Cobb's own explanations etc. which illustrate this general trend. It is not a perfect rule of thumb which holds absolute, however it generally applies to within a couple of percent margin of error.
One example was a 700 HP super charged coyote V8 on a S197, guy bought it used from out of state (lived in Cali), so he had to have the car re-tuned to 91. Made 680 HP after adjusting for 91 octane.
680 / 700 is about a 3% difference. Cobb's web site provides the following illustration as well: https://cobbtuning.atlassian.net/wiki/display/PRS/Ford+Mustang+EcoBoost+Map+Notes
Your free to say whatever you want however untrue it may be, suggesting my engine is going to fail with no evidence is quite a leap, especially since Livernois has a 20+ year history and has to date not failed a customer car (yes we vetted out this claim before as well). You know nothing of me, of my car, how it's running etc...I would call that wild and outrageous speculation at best.
A value that isn't -1.00 isn't necessarily indicative of a bad dune. OAR is a scaling factor based on knock detection, its used by the PCM to optimize ignition timing tables which are scaled according to fuel quality if all other conditions remain the same. Mechanical malfunctions could certainly affect that, however assuming the engine is mechanically sound, then your at the mercy of the fuel available in your area regarding OAR. A value of -0.61 for a 93 tune and -0.74 for 91 tune is near the maximum permissible scaling factor which is -1.00. My car ran the same OAR values with the stock PCM software when I first started messing around with data logging, which is what it was at last time I checked. I have not checked since the temperatures drop, but intend to do so in the near future just for my own curiosity.
