Does the factory unit have pre outs amps? If not what did you go with instead?
LkySpade Active Member Joined Nov 5, 2020 Threads 12 Messages 35 Reaction score 11 Location Illinois First Name Christopher Vehicle(s) 2015 mustang gt Feb 25, 2021 Thread starter #1 Does the factory unit have pre outs amps? If not what did you go with instead? Sponsored
Cathul Well-Known Member Joined Sep 4, 2017 Threads 5 Messages 931 Reaction score 426 Location Germany First Name Peter Vehicle(s) Ford Mach-E Feb 26, 2021 #2 Yes and no. The ACM can be programmed both ways, i.e. having powered outputs, variable line level outputs or fixed line level outputs depending on which car it goes in. And it all goes through the same pins in the connector on the back of the ACM.
