Gronk
So i have recently replaced my rear deck speakers with JBL GTO638's, front 6.5's with JBL GTO628's, and the front mid-range 3.5's with JBL GTO329's. I have disconnected the A-pillar tweeters since the 329's are two way with built in tweeters.
While a noticeable improvement, still not happy with the lack of power overall and lack of bass from rear.
So, I'm going with an aftermarket Alpine MVR-V500 5-channel (I may add a sub eventually) and was planning on using the Molex connectors from Mouser to tie in some RCA adapters at the factory amp input connector for the LF, LR,RF,RR signals. So it looks like I will lose the center channel completely.
Also, will I need crossovers to combine the front 628's with the 329's on the LF,RF channels? Or can they be wired in series (2ohm + 3ohm=5ohms)
Crazy how they do the factory signal processing!
Seems others have used the JBL GTO series as replacements as I did but swapping amps is now getting more challenging.
My goal is to have nice full range sound from front and rear with balance/fade capability and retain all NAV and hands-free functionality.
Thoughts?
Thanks!
Thoughts?
Thanks!
