Factory Shaker Sub Woofer replacement?
19 GT Premium
Houston
Rich
2019 Mustang GT Premium
I want to replace the woofer in a Shaker factory sub box for an upgraded woofer. I took the factory woofer out of the enclosure, but it looks like some kind of proprietary speaker. It has blade terminals on two sides of the speaker, with two wires each. Two red on one side, and two blue on the other. I haven't seen a speaker like this before. There is no ohm indicators on the speaker either.
Any thoughts?
ETA...
I discovered the "Dual Coil" subs online. Question now is which one. Measurements on the factory speaker shows a 7.5" paper cone, and 8.5" frame size. It seems I have a choice between dual 4 ohm, or dual 2 ohm coils. What is the suggested replacement using the factory shaker amp? I'm guessing the factory speaker is considered an 8" speaker?
Thanks!
69mach1-395
central nm, usa
2016 RR GT/CS
I thought about upgrading also, but by converting to a 10" somehow, like an adapter of some sort...
Paul K
Long Island
2015 Mustang GT Premium PP Recaro
Any thoughts?
ETA...
Thanks!
I replaced my Shaker factory sub with this https://www.amazon.com/Pioneer-TS-SW2002D2-8-inch-Shallow-Mount-Subwoofer/dp/B00JQTU434
It's a dual 2 ohm.
It made a substantial improvement in bass response.
catchthecarp
STL MO
2017 White Platinum Premium GT
Chef jpd
Brooklyn, NY
Don't forget to polyfill the box for some extra thump.
and +1 on the RF Punch.
Chef jpd
Brooklyn, NY
Is that a direct replacement or did you have to fabricate an adapter for it to fit?
Direct fit, plug and play. also, order the protective grill.
Chef jpd
Brooklyn, NY
Dual voice coil 4 ohm
Rash
Cary, NC
2018 Mustang GT Magnetic/Showstopper Red, 401A, Active Exhaust
Is the factory sub 4 ohm? The link in post 4 of this thread is for 2 ohm Punch. How much difference will that make? I don’t want to damage the factory amp.
Chef jpd
Brooklyn, NY
You can go with either one, won't make a huge difference with that small factory amp.
Harrry
Boston
Harry
2016 Mustang GT Premium
That's not true. I've heard on the web the Ford sub amp is rated at 75 watts (I intend to measure it soon). So with a 4 ohm sub, the amp needs to deliver 17.3 Volts RMS at 4.33 amperes. Verify by Ohms law, Watts = Volts x Amps or 17.3 x 4.33 = ~75 watts
To get the same 75 watts at 2 ohms, the amp needs to deliver 12.3 Vrms at 6.1 amperes, or 12.25 x 6.13 = 75 watts. The amp will need to come up with 41% more current to drive the lower impedance, but if its not designed for this the 2 ohm load may cause it to fail.
HoosierDaddy
Randy
catchthecarp
STL MO
Did you have to do any modifications to make it fit, and work?
No modifications, remove factory sub and replace with the Punch.
