Factory Grill Engineering
michail71
2018 GT 401a A10
I'd love to change out the grill, mainly for a badgeless look up front. However, I've been concerned about a few things that would be lost in the factory design. I'm sure the engineers had reasons.
  1. The intake portion of the factory grill only has a few of the honeycombs open and two of them are half open. What is the purpose of this? There must only be a couple square inches of airflow at the grill to the intake.
  2. The radiator portion of the grill has the active shutters and is blocked off as well outside of the shutters.
I'm thinking the design choices are to keep turbulence down and increase fuel efficiency? I live in a hot climate so I don't think I'm in big need of keeping the engine warm/hot. Also, most of the driving I do is around town with some mixed highway. So I'm not doing long stretches at speed.
At some point I may also want to add a Roush or Steeda closed airbox.
Idaho2018GTPremium
Idaho
2021 Camaro ZL1 A10
You're on point. A Ford engineer has stated they block off the ones that aren't needed to help improve aerodynamics compared to if they were all open. If they were all open, there would be more air going into the engine bay, causing lift and increased drag.
Blue Horse
Mustang GT
Just make sure your ground speed indicator on the instrument panel is working,that way when you go airborne you will know you have the right amount of airflow and not to much lift,that was one great feature on the S550 that Ford came up with. LOL.
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Would an aftermarket vented hood resolve the issue of increased drag?
I'm looking for better cooling as my car heat soaks bad when the temps are over 90.
Idaho2018GTPremium
Idaho
2021 Camaro ZL1 A10
Regarding the aerodynamics - I'm not certain. It would seem so, by allowing the air going in somewhere else to escape besides down and under the car after swirling around everything in the engine bay. At most typical speeds it's probably negligible, however. The vented hood may help your heat soak more than the concern about the aerodynamics/drag. It seems a good sized vent would give the hot air a natural place to escape. The hot air will naturally rise so even without airflow I would argue that it's better than an un-vented hood in the heat soak department. I'm not an automotive engineer so this isn't gospel (I am a mechanical engineer, though, for what it's worth).
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
You have an '18. Just get a Bullitt grille.
michail71
2018 GT 401a A10
I may, I'm just thinking it all through. I like the look and cooling improvements but am contemplating the aerodynamic trade off.
Zelek
Hutto, TX
2021 Mustang Mach 1
Get a Velossatech big mouth and you'll be convinced to open up the honeycomb fully.
Stangnut
S.E. Alabama
Jason
2019 Bullitt BHG
The problem started with the '05 body. The grille was so open that the hood would flutter/shake a lot at high speeds. That's one of the reasons the grille is so closed off now.
michail71
2018 GT 401a A10
I was wondering if aftermarket grills were the reason I've seen posts of some people having hood issues.
michail71
2018 GT 401a A10
Been eyeing that for about a year. Thinking of combining it with a JLT or closed Roush.
jacknifetoaswan
Charleston, SC
What types of hood issues? The only ones I've heard of are flutter of the metal, which happens because it's super thin aluminum, and leading edge hood corrosion.
As for the grille opening, yes, done for fuel efficiency issues, as well as to optimize cooling for the majority of users (remember, the same grille has to work for the person in Ontario, Canada, and Miami, FL). I gutted my stock PP grilles on my 2016 and installed a mesh grille insert from customcargrills.com. Living in Orlando at the time, I saw an immediate decrease in IATs of about 3-5 degrees F. It's not a lot, but it's enough. I did notice a slight decrease in fuel economy around town, but given that Orlando is a clusterfuck of traffic, that's unexpected.
JR
908ssp
Michigan
Alex
2015 GT/PP white
Yes venting through the hood relieves pressure under the hood and increases the air flowing through the radiator and heat exchanger if you have one.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Blocking off large portions of the grille are both for aerodynamic performance at speed (lift/drag) and drag itself (fuel economy). The intake is partially blocked to prevent significant snow and water ingestion during the winter and car washes.
MasterCylinder
Fort Worth, Tx
(sold)17 GT
Stock wise if you look where the wipers are the hood is actually more open than you'd think. In fact it is so open I thought someone had left a piece out last time it was at the dealership.
