Expanding Exhaust Options?
2017 GT350 Avalanche Gray
Considering the use of active exhaust for MY18+ non-GT350 Mustangs, has anyone wondered if the aftermarket options for 5.0's would be easy to install on the GT350? The system and bends are, for all intents and purposes, identical... The hangers and brackets look to be/should be in the same location... The valve control for "sport" looks to have the same mounting point...
I know some of us would like to retain the ability to keep the exhaust mode option, which the current 350 options are limited to the Magnaflow system. For me, I would like more options, and the thought of removing the faux exhaust tips is highly enticing.
galaxy
St Louis
'17 GT350
If I'm understanding correctly, the Magnaflow is not the only 350 option. Borla has two options that retain the system.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
Corsa also makes a system for the GT350. I would highly advise against trying to finagle a 5.0 system onto a GT350. The mufflers have been designed by those companies with the 5.0 in mind. Also, you would have to see if the actuator would even mount up to one of those systems. Personally I haven't seen an '18 GT actuator module before so I can't comment on how they would work.
Creedog
Somewhere
2017 Shelby GT350
FP By Borla, Borla ATAK, Magnaflow, Hooker Blackheart (have to contact them directly), GTHAUS (very expensive). These are the ones I am aware of at this time but there maybe more.
Creedog
Somewhere
2017 Shelby GT350
The OEM actuators will not work with the Corsa system I believe.
toastedbutter
Ah... Forgot about Borla (and FRPP Borla) system keeping the valves.
toastedbutter
Same, and the few OEM parts sites (Tasca, White Bear Lake) I follow don't have the parts online, so it's hard to compare.
Brostang
Hampton Roads
17 GT-350 Oxford & LB
They have a narrower spacing between the inboard tips. It would be a headache trying to reposition the tips (tailpipes) without having to lengthen piping or reweld hangers, etc. 2018s have the same tip position as the 15-17 roush quad outlet bumper. Look up the GT350 valence thread on the 5.0 subforum for a better idea of what im saying.
bullitt5566
Sumter, SC
2017 Lighning Blue GT350 2010 Blue Flame Raptor 2001 True Blue Bullitt
The GT exhaust is 2.5 inch and the GT350 is 2.75 inch. Not sure a GT system would match up with the GT350 mid pipes.
Scott
