Exhaust actuator harness help
raceguy388
Michgan
17 GT350
I’m looking for some help on part numbers for the short wiring harness that runs from the exhaust valve actuator to the main harness. I managed to pull the wires out of the back of the connector. I hope I can buy the harness only and not the whole actuator. Thanks for the help
Tank
9/11 - Never Forget
Above the Notches
G0853
Sounds like the wires might not have been seated securely??? Can't you just re-insert them into the connectors?
DocWalt
SE PA
GT350
FR3Z 14A411 H - Drivers Side
FR3Z 14A411 J - Passenger Side
Got those from TMO, those are for the short harness that's wrapped in the reflective heat wrap
Epiphany
Global
I like to disassemble things.
Engineering numbers...
Driver or left side.
Passenger or right side.
DocWalt
SE PA
GT350
I wish Ford's engineering numbers were easily cross referenced with "real" part numbers... :(
raceguy388
Michgan
17 GT350
Thank you for the help!! I really don’t understand why the part number is not on the tag!!
shelbygt53
California
Kevin
GT350R
If anyone can help me with this, It would be a amazing help, does anyone have the part number of the harness that the exhaust valve actuator plug into. I have the two small wires from the actuator but I need to know what harness I need to plug them into. Please help if you know, thanks
