Engine Vibration at 2000 RPMS
oscarbih
California
Oscar
2015 Mustang GT PP
I have a 2015 Mustang GT that got its stock headers reinstalled but I noticed a vibration around 1500-2000ish RPM and then it would go away. I rev'd the car up to 5k RPM to see if it would vibrate in any other RPM however the vibration would only be felt when it went through those RPMS. The car idles just fine and visually the engine doesn't shake or vibrate when in those RPMS. The Vibration is only felt through the interior especially more on the gas pedal. Would anyone have any idea where this would be coming from? Thanks!
WhitemarePP
Arkansas
Corey
2015 Mustang GT PP
I have the exact same problem. However, I’ve always had the stock headers. My car is a 2015 Mustang GT PP, manual transmission. Did you find a solution? It’s driving me nuts. 2000 rpm is cruising rpm so it makes going on a trip very frustrating.
sk47
North Eastern TN
Jeff
Hello; Some years ago read an article radial tires. Seems back then at least they had a built in sympathetic vibration. Somewhere around 45 to 50 MPH if memory serves. The nature of the tires I suppose. I looked for and did find such. Was not much. I changed gears to see if RPM's mattered.
I do not know the rear end in the OP's car. More than one ratio was offered. Could it be what I think of a lugging? I can only go so slow in top gear in my manual car without vibration.
arevazo
Colorado
Alonzo
2021 Mustang GT
Did you ever get this figured out? I’m having the same exact issue now in my 2021 ESS car.
WhitemarePP
Arkansas
Corey
2015 Mustang GT PP
I was able to fix it by replacing the clutch. I had a McLeod RST and a lightened flywheel. They apparently do not balance as a unit.
After new Exedy clutch and flywheel, no more vibes.
Sometimes aftermarket HP parts are the wrong way to go unless you’re going to be at the track all of the time driving full throttle at high rpm.
