SolarFlare
550whp on an NA 2018? Someone was lied to.
The numbers look to the in the ballpark of what is expected given the blower is still being limited by the stock TB, stock airbox, stock sized panel filter, and factory headers/cats.I put down 675 wheel on a stock 2015 car, whipple canned tune, on 91 at 3,500 elevation on a whipple stage 2 and I was disappointed because others are cracking 700's easily. I'd be upset if I was putting down low 600's after all that money spent when NA guy's are getting 550whp on 18's.
He's on e85, has long tubes, and other bolt ons, If I wanted to do that I could of done it. I will be sure to tag you when I have long tubes, e85, and a intake so you can see how much of a difference those mods make ;)I put down 675 wheel on a stock 2015 car, whipple canned tune, on 91 at 3,500 elevation on a whipple stage 2 and I was disappointed because others are cracking 700's easily. I'd be upset if I was putting down low 600's after all that money spent when NA guy's are getting 550whp on 18's.
Here you go - 536whp (7:50)550whp on an NA 2018? Someone was lied to.
Actually with the 6r80 most want to dyno in 5th gear but guys with 315 and possible 331 cannot because it hits the speed limit of the ecm,which is 178 mph.For example my last dyno a couple weeks ago my car shut in 5th gear at 6200 hundred rpms,had to do the pulls in 4th.But u are right about the speed of the wheels on the dyno being dangerous,i did not like the 5th gear pull lol.It is ideal to dyno in a 1:1 gear but that is not always possible. Case in point, the 6R80 does not have a 1:1, so 4 gear is used since it's close to 1:1. Other vehicles such as the F150 can be dangerous to dyno in 1:1 due to wheel and driveshaft speed.
Nice results OP. This is REPEATABLE power to expect on 93 octane when using stock exhaust, stock throttle body and stock intake.
Patch it, that has been fixed already so you can go as fast as you need tooActually with the 6r80 most want to dyno in 5th gear but guys with 315 and possible 331 cannot because it hits the speed limit of the ecm,which is 178 mph.For example my last dyno a couple weeks ago my car shut in 5th gear at 6200 hundred rpms,had to do the pulls in 4th.But u are right about the speed of the wheels on the dyno being dangerous,i did not like the 5th gear pull lol.
Please don't link up those youtube gomers,Here you go - 536whp (7:50)
I guess my question was intended to qualify the gear ratio effects results of the graph and it's peaks or does it not? I understand the trickery needed to avoid a mishap or limitations imposed by the built in granny but doesn't the the trans ratio being in an overdrive gear negatively skew the end results?It is ideal to dyno in a 1:1 gear but that is not always possible. Case in point, the 6R80 does not have a 1:1, so 4 gear is used since it's close to 1:1. Other vehicles such as the F150 can be dangerous to dyno in 1:1 due to wheel and driveshaft speed.
Are you going WOT at 3k rpm in an auto car without downshifting? Why?Impressive.
Everyone gets all excited about peak power figures...and I don’t get it.
For the sake of argument, let’s assume the figures are in fact completely accurate for both sheets.
I’ll take your 300whp @ 3k over the Whipple’s 230 any day of the week.
That’s over 20% more power on tap in the places you actually use it on a daily basis.
The fact that it’s STILL making more power than the Whipple at 6k doesn’t really do much for the Whipple’s cause except to produce dyno sheets with big numbers at the top.
As a person who’s looking at swapping out the blower, the options are either get slight improvements going from Gen 2 Whipple to Gen 4, or, be done with it and use a blower that produces actual torque and be done with it.
I know which option will be far more fun on a manual car.
I think you just answered your own question.maybe we just drive differently.
I’d say we most certainly drive differently.Are you going WOT at 3k rpm in an auto car without downshifting? Why?
Ideally, you'd downshift and be at a higher RPM so you can accelerate quickly. I've never been concerned with power numbers under 4k RPM but maybe we just drive differently.
