Jay-rod427
Need to drive easy several miles before flogging on it. If Nguage see alcohol learned flag checked, if SCT just drive 10+ miles to be safe. The fuel trims and AFR will dance around a while before it settles and learns. Without the Nguage alc%, or testing it you have know way of knowing the blend, and/or what afr should be.I found E85 after going to all the stations listed as having it and not actually having it.I found a Shell gas station that states it is E85, going there tonight hopefully around 5 to 10 miles to empty then adding a few gallons of E85 and then tuning right there at the gas station and then waiting for a few minutes and driving gently for a few miles until I see AFR changing then I'll do a WOT test and log. The E85 tune I'm ordering the tester from Amazon and using that at the Shell station before tuning and logging it.
also if you only add a couple gallons E85 it will be a weak mix with what's left in the tank. Even at 10 miles till empty that's still a gallon or more. Personally I would just top off the full tank with E. 1 gallon to even 3 gals top shelf full E85 is still not a great mix for the most potential. 1 gal to 12-13 gallons tho is a lot stronger mix.
Luckily all our stations around here just changed to summer blending at the pumps. Tested 10 gals this weekend at 87%! just in time for race season.
