e85 mixing
craigsix
overland park ks.
craig
2018 mustang gt
why does it say e15 on the filler neck? what does 2 gallons of e85 to 14 gallons of 95 octane equate to?
Vinny@JLTPerformance
Chesapeake, VA
2015 Mustang GT
Problem is you're assuming it's E15 everytime, and you assume you can mix it the same every time.
These assumptions are going to leave you with a broken motor.
You'd be better off with 93 and Torco additive, vs attempting your own cocktail mix of E85.
craigsix
overland park ks.
craig
2018 mustang gt
thank you. im running your oil catch can my 1st mod. these made a big difference un the hemi motors short term and long term knock retard.
Choking_Victim
Arizona
Justin
2018 A10 GT PP
One would think that the calculation should be done prior to burning it up through the motor?? :doh: Regardless like other have said this is a shit idea on current tune and injector.
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
Regular 93 is supposed to be e10 so 2/16 x 85 + 14/16 x 10 = e19.375. Pure math dude, you should have paid attention at school.
I just bought the HP Tuners suite and an nGauge, so I'll let you guys know what the ECU does when it "sees" extra e85 in the gas.
I've personally seen how some ECU's (Mazdaspeed3) use the wideband to drive the injectors to add fuel when e85 is added. So if the Ford ECU is the same I'd expect to see the injector duty cycle to go up to add fuel and get lambda back to target, usually 0.8 at WOT.
I'll post when I've had a chance to play.
craigsix
overland park ks.
craig
2018 mustang gt
thanks my 93 is no e. at my local bp. what does that come to? i suck at math. thanks smart dude. im going to cut back to 1 1/2 gallons e85 to 14 1/2 95 octane.
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
Ok, so now you have 1.5/16 x 85 = 8, so that pretty close to the e10 the rest of us are pumping.
2 gallons of e85 to your zero 93 will be 10.6%.
Personally I wouldn't bother with e until you go force induction.
anotherneon
15' base GT w/3.55s
:tsk: How about you listen to the advice given and not put any E85 in your car?! :doh:
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Mixing E85 with pump gas is not smart unless you're tuned for it. In which case just go full E85.
Brian@Vossen
Miami, FL
Brian
A Mustang with a V8
I'm running e85 with the upgraded 47lb injectors and a Lund tune and you can definitely feel a difference. Lund was awesome with helping with the datalog sessions and always replied with an update promptly
beefcake
Bethel
2018 Ford Mustang
yep, if you want to run e85, then I would suggest letting us do a lund tune for it and doing it properly
