Driver Side Master window Switch
blakedanatural
West Chester,Pa
Mustang 5.0 Premium
Hello y'all,
I have a 2015 Mustang GT premium and my driverside window is not functioning at all. The passenger side is working with no issues. I checked the fuse on the passenger side bottom and in the hood fuse box and both fuses was good. I took it apart and cleaned the connectors with dielectric grease and reconnected and still did not work. The only solution I have is to order a new master switch on the driver side. If anyone had this issue and corrected it please let me know how and if you ordered a new switch where did you order from.
Thank you ,
Blake
StormNorm56
Leesburg, FL
Norman
2017 Mustang Ecoboost Premium
Hello y'all,
Thank you ,
Blake
My situation may not apply or it may help you. My 2016 Ford Explorer Sport's front passenger window became intermittent down from the driver's side control. This occurred sometime after I purchased it new. Never took it to the dealer since intermittent faults are hard to diagnose and repair. I lived with it for a couple of years. One day after that window failed to go down, I held down the driver's control for that faulty window to the first detent for a few seconds and the window went down. I don't recall if I then went to the second detent. I would do the first detent thing whenever the window failed to go down and each time it worked. It's hard to believe but the window has operated flawlessly for a couple of years now like it fixed itself. Good luck.
I have a 2017 Mustang Ecoboost Premium, too.
blakedanatural
West Chester,Pa
Mustang 5.0 Premium
thank you
jheissjr
PA
Jeff
S550
A functional switch conducts electricity and a non-functional switch does not. Check it. No need to guess. There could be multiple electric modules, wire harnesses, fuses, connectors, relays, CAN communication busses, limit switches, electronic motor involved with the window operation and the switch is probably only part of the operation. Troubleshoot it with a wiring diagram instead of guessing parts. If its not the switch the decision in your hands is which costs less, the wiring diagram or the initial diagnostic fee and follow on hourly rate at a dealer.
GregO
Illinois
S550 GTPP
Hello y'all,
Thank you ,
Blake
My 2015 switch did the same. Bought a new switch and issue fixed. Be cautious on your vehicle build date when ordering the replacement switch, Ford had a mid year design change on the plug style. There are two totally different styles of plugs used on 2015 models, mine is actually a 2014 build date. I believe the change occurred around 2nd quarter of 2015.
Being you have a 2015 you might want to consider ordering from your local dealer based off your VIN code to assure the correct switch is ordered. If you order online I’d suggest pulling your switch to verify plug style to match the online photos of the part that is if the online pictures are of the actual part and not just a representation for illustration only.
Yes I know how could a dumb switch be so complicated to order, but it is if build date isn’t factored in.
Also don’t get dielectric grease on the electrical pins and sockets, the grease is not conductive.
blakedanatural
West Chester,Pa
Mustang 5.0 Premium
Thank you and everyone else with your help. I took the door panel off and took every connector detached and spray crc electric cleaner the dielectric grease around the plastic parts and reconnected. I turned the car on and that bad boy went up and back down. I was so happy cause I was going to buy a new master switch and motor. Thank God for mustang6g forums
blakedanatural
West Chester,Pa
Mustang 5.0 Premium
I tyoothe door panel off and disconnected everything . I used electric spray cleaner fron CRC and put dielectric grease around the plastic on the connectors and it worked. So glad I didn't buy a masterswitch or motor. Thank you for your help
jheissjr
PA
Jeff
S550
Nice. Glad it turned out to be just a connector reseat.
blakedanatural
West Chester,Pa
Mustang 5.0 Premium
Well I spoke to soon. It started messing up again and now it stopped completely. I ordered a new masterswitch from Ford and its still not working. I hearing like a click when I depress the window switch. So it sounds like power is going to the motor . So it sounds like the motor went bad. Its receiving a signal Im sure. You have any other suggestions it will be appreciated
