Drag racing with a boosted Automatic Mustang
Getdownonit
Getdownonit
George
2016 Ford Mustang GT Premium
In trac mode mine disables traction control. I have plenty of logs showing tire spin with no torque management kicking in. Mine is the premium so on a basic Yes you have to disable advancetrac.
I have premium.
Getdownonit
Getdownonit
George
Set to Track Mode and turn off advance track. Leave car in D not S.
Tommy V
Brookly park Md
Tommy
SolarFlare
S. Fla
2015 CO GT
Dude your talking about two different things,yes u can turn off advance trac and trac control.But when it comes to the modes he is asking about,u have to be in either trac,snow/wet,normal or sport.When u put in trac mode it turns trac control off.But the car is in one of them modes.
Dude, the car in track mode DOES NOT fully turn off advance trac unless he turns it off, stability control remains on!! The OP should put it in sport + and turn off hold traction control up until it says advance trac off.
Dennisn
Chicagoland
16 gt
Nothing fully turns off advancetrac unless you pull the abs fuse or pull one of your wheel speed sensors. When you do that you lose abs as well.
Tommy V
Brookly park Md
Tommy
Never said putting car in track mode turned off advanced track.Trac control off advance trac off and in track mode.Do u have the the toggles for different modes?I put mine in track mode for throttle responce only!!!!!.When i put mine in track mode it automatically turns off trac control.I then turn off ADVANCE TRAC CONTROL,which with the premium models is the most u can do with turning off trac/stability/clutch protection also which are all tied together.Now maybe guys without the toggles have different procedures but what i told the op is correct.
Tommy V
Brookly park Md
Tommy
Absolutely!!!.And thats the reason why guys that use launch control with trac and advance trac off can sometimes run into bogging out when launching with slicks or dr.Also if u pull fuse 62 or whatever number it is u dont have linelock.Abs/trac control/stab control all tie in together.
jvandy50
H3249
AR
jason
23 Bronco, 18 ZL1-1LE
So when i put the car in track mode, then turn advancetrac off, i STILL am not done with the nannies??
Tommy V
Brookly park Md
Tommy
Depending on your tuner yes,the trac/stab control can be tuned but not completely turned off.With a good tune and advance trac and trac turned off its very difficult if the nannies are doing anything.Guys with Manuals and use launch control can sometimes run into small issues depending on their launch method.
Getdownonit
Getdownonit
George
I know how to do this as I have done it a few times. (turn off hold traction control up until it says advance trac off.)
NicksRubyRed15GT
Chapel Hill NC
Nick
Deep impact blue 16 GT
1 Turn off advance track
2 back in water and do a burnout
3 stall the car as high as it will go without pushing you through the lights and go
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
No to #3. Most folks get much better 60's by smashing vs holding with the stock converter. If I remember right the Ecu will pull timing if you try to foot break on the stock converter. I'll look over my logs to verify. But best 60's on stock convert is hold then smash the go pedal.
MyLilPony
Naw It's Stock
Prosper, TX
Kris
