Drag Racing Alignment specs?
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Hey guys, In about a week here im going to update my suspension a bit. Moving to Steeda Drag Springs, Viking Crusader Rear shocks, Koni Adjustable front struts, Adding(already have Steeda Stop the Hop Ultimate Kit) in Steeda camber bolts up front and Steeda Camber Arms out back along with Ford Racing 1500hp axles. My question was obviously after all this I will need an alignment are there any recommended specs to ask for that are better for drag racing?
NGOT8R
Adrian
2019 Bullitt
Sounds like a nice plan. Will your car be a dedicated strip car or a combination of street/strip? I have every suspension part available on my 2019 Bullitt (which will be mainly street, but some strip) and I just asked BMR‘s Tech Support this question. Here is what they told me.
FRONT:
Camber: -1.50 (+/-) .30
Caster: 7.21 (+/-) .75
Toe: 0.05 in per side, 0.10 total toe in
REAR:
Camber: -1.25 (+/-) .25
Toe: 0.13 in per side, 0.26 total toe in
Thrust Angle: ZERO!
Whitedevil95
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
FRONT:
REAR:
Thrust Angle: ZERO!
That is very helpful! This is definitely a street strip car. After this I will have most of the Steeda catalog on the car for drag stuff.
Decible
Georgia
Sam
2023 Mach 1 HP
🙌🏼 Thank you! I needed this!
ryanking5.0
Ohio
Mustang 5.0 GT 2021 Coupe
FRONT:
REAR:
Thrust Angle: ZERO!
This is really helpful! This is for supercharged mustang right? Is your mustang supercharged or turbocharged?
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Rear camber for a flatter launch should be no more negative than -.75°
Ideal for drag only would be basically 0.0° (I like to run -.25 to .50°)
My 60' improved .15 going from -1.25 to -.50°
-1.25° is for street use and within factory positioning.
