Does whipple use same coolant as engine?
doodguy
Ruskin, FL
2015 Roush Stage 1 Supercharged Mustang GT
Im about to start my install this week, but does whipple have separate engine coolant or does it tie into engine coolant. Just curious.
Furore
Honolulu, HI
2015 Mustang GT Premium 6A
Whipple comes with it's own oil. If you are referring to the intercooler coolant.. I use 50/50 Distilled water Ford Green stuff.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Using the same as stock works perfectly fine, especially if you have your car seeviced sometimes. This way someone who doesn't have knowledge of the supercharger modification can't add a different fluid than what your using and blend you mixture.
I have decided to use a different color fluid simply to let me know exactly what system is leaking if I were to see a certain color antifreeze on the ground. The supercharger will have its own closed loop coolant circuit and the engine will have its own, they are not tied together.
Phoenix
Instagram: PhoenixNFA
Central Texas
2016 GT350 Tech AvGrey/Black Stripes
are you trying to figure out if its on the same circuit as the engine coolant?
doodguy
Ruskin, FL
Yes. Does the coolant flow between engine and intetcooler or are they teo totally separate reservoirs never meet?
Phoenix
Central Texas
i know the kenne bell kit is a separate system for the I/C and blower case cooling. not sure about the whipple. id imagine it is.
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
Yes its a separate system.
Livnpaintball2
Trophy Club
16 GTPP
Good idea with the different colors, I'm going to do that as well!
When my whipple arrives.
