Do you use your OEM wheels for snow tires or buy a second set?
Nickyweg
Cleveland
Nick
Lincoln MKC
Going to be needing to buy some snow tires for my 20 GT. I’m unsure if it’s worth it to buy a second set of wheels or to just use my normal wheels that it came with. What does everyone else do here?
I have the stock black paint 18 inch wheels.
kz
West Chester, OH
Mustangs & F150
Definitely second set of wheels. Unless instead of spending 20 minutes to swap the wheels you'd be rather going to tire service place to have them mounted... Also, second cheap set would quickly pay for itself (unless you have tire machine & balancer at home), if you have a second set, it's a no brainer.
Zooks527
2019 KB GT, 401A, 6MT, PP1, S&S, MR, AE, B&O / 2005 Toyota Tacoma
Second set. I went with 19x9 Ford Performance Boss 302 wheels, so no need for spacers, no need for centering rings, and I can run a rotatable square setup for the winter tires.
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
Buy a second set. You can get stock wheel in the for sale section for next to nothing.
Balr14
SE Wisconsin
BMW Z4 M40i
I suggest a smaller wheel with narrower rim, if you can find one that fits your Mustang. They are much better at handling snow than and bad roads.
HolubS
Eastern Iowa
Scott
2018 Ecoboost Premium Plus Coupe in Lightning Blue
I bought a set of cheap black 17" rims for my car from Tirerack, with slightly narrower and taller sidewall tires. Have had good luck with the Michelin X-Ice tires getting around.
ChaoticFury09
Toronto Ontario
Nathan
2019 GT Premium (Automatic - Magnetic)
Using my 18” oem as winters and I have my nice aftermarket rims for summer.
Nickyweg
Cleveland
Nick
Lincoln MKC
But would 17s fit on a GT? I know the GT has bigger brakes than the EB.
ChaoticFury09
Toronto Ontario
Nathan
Grimmer
Utah
2016 GT Manual
Second set for sure. Stock 18" for the taller and narrower "advantage" over the snow.
It is worth it to reduce the number of times the tire shop has to man handle your rims to swap the rubber. Plus you can take just the tires in when it is time for new rubber so they won't man handle your car either.
Monopoly
Toronto
2017 Mustang GT, 2012 Civic Si
I bought a dirt cheap set of steel rims with Bridgestone Blizzaks ws80 for $300. Non PP car the 18x8" fit fine. They have approx 50% tread left on the rears and tested in heavy snow here North of Toronto this February.
Car handles really good I could easily daily drive this thing. I did add about 75lbs of weight in the trunk.
Steel rims are hella ugly but they wont leak and are super strong!
EFI
Masshole central
5.Br0
OEM wheels are being used as winter wheels since narrow tires are better in the snow and cheaper.
I run nicer looking and wider aftermarket wheels and tires in the summer when dry grip matters more.
Chola
Laurel, MD
Rajarajan
Honda Accord 2005. 2019 Mustang GT PP1 6MT
That's what I did, and now have two identical set of wheels. Now wonder if I should have gotten a different set for a different look in winter.
jimmerheck
Vancouver, Wa.
Jim
2016 Mustang GT Cal Special
I bought a set of 18" GT wheels for around 150 in pretty good shape with TPMS sensors in them, which I thought was a hell of a deal, and now only put them on when needed. I found some Toyo 235 50 18 unstudded tires on Craigslist so thats my snow set up. And even though I have the compact spare, when I go on a road trip, I throw a spare un studded snow tire in the trunk in case of emergency. Beats mounting up that compact spare. My car (Cal Special) uses 19 X 8.5 up front and 19 X 10.5 in the rear, (I had them widended) and all of them are about the same diameter.
