do NOT consider a 275/30R20 set up
Zemedici
Kennesaw, GA
Josh
2015 GT/PP
Except this has nothing to do with that and is simply the wrong tire size on a wide 20" wheel
TRUUUUUUUUUUUUUUU :cheers:
My car looks good on 20s I think....
101charley
Franklin TN
Charley
2015 GT Magnetic, 400A, 6AT, 3.55, MBRP Street
The 30 ratio is just not enough sidewall for a decent ride and is risky in terms of denting the wheels. I once had Vredestein Ultrac Sessanta in 285/25/20 on my 2006 E55 AMG and the ride was terrible. Big mistake. Wheels were soon dented.
panic
Spain
2015 Mustang GT
I did not. I just played with a tire size calculator, Google images, and crossed my fingers. FAIL.. Alot of BMW Audi set ups look good with this size. They were probably lower and have a smaller wheel well. I knew I was taking a chance, had to find out the hard way. Luckily the tires are Federals, not MPSS!
My 2014 Klass E 500 coupe' has the 275/30/19 and it's BS, I've changed those fucking tires dozens of times, you just touch a stone on the road and it's done...
On the other side you can't even change tires measures because the car will start shouting evil ''warnings''....
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
There's a certain blues on red car with this tire size up front, and it looks 1000 times better.
Yes thats my clients DIB we did on a 20x10 & 20x11 275/30 & 305/30 Toyo tires
What are the specs on the wheels you used? and those images you took how soon did you snap those after or before you did the spring install?
Bomicino
Bomicino
gilberts, il
Tony
15 ecoboost
20x10 +40. Springs were done in april, 13k on them. Im tossing around the idea of 275/35 fronts and 285/35 rears. I know I could go bigger, but this little 4 banger doesn't need 305s....yet.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
A 275/35/20 will do this way you can also rotate the setup all around and save a bit of money as well on rubber.
Bomicino
Bomicino
gilberts, il
Tony
15 ecoboost
Hotchkis Y-sport. Got them stupid cheap. Originally $299/each, but tirerack had them listed as a rear fitment only, front were sold out. Clearance for $99/each, and with wholesale through my work, got them for $89 each. Slightly concave, but 32 lbs/each. Not light, but same as the PP wheels.
Asonitez
I go 71 in a 70 *REBEL*
North Carolina
Tristian
2016 Oxford White GT Premium
i tried to buy 4 the other day... they are only 3 graphite and 2 machine face.. :( lame
Bomicino
Bomicino
gilberts, il
Tony
15 ecoboost
You could get them powdercoated. Thats what I did with my current set up, they were different colors that I got on closeout from tire rack also. Still would be cheaper than most other options, and then its unique.
Old 5 Oh
Wilder, ID
David
2015 GT Premium AT
I don't like the rim protector look. This is just too extreme. Glad you are going a different direction, OP.
tevaburns
Clawson, MI
Tiberius
2015 GT Premium PP
For those HRE FF15's I bought from you I was going to do MPSS
285/30/20 front and 305/30/20 rear
I was hoping for less sidewall. Am I going to hate this setup?
