285/30R20
jenksdrummer
Jenks, OK
2019 Mustang GT Premium
I've got my car on order; thinking of getting some alternate rims for non-track / daily driving. PPK2 is what I've got on the order...
Thinking of AR924 in 20x10.5 and 20x9, as they have a similar look to the PPK2 wheels that I like, but are a bit slimmer so easier to fit all season tires to without undersizing, and they're 20" so they might look good(er) - to that, I'm not entirely settled on the wheels since they are similar, but, is what I like for now.
Rear, I'm thinking of putting on 295/30R20 on them, which overall will be .4" more radius, but, will also be .4" thinner than stock. Would it clear? Likely less or no poke, I imagine. Some of that of course depends on the offset of the PPK2 wheels vs what I end up with, but I'd be surprised if they are different than the PPK1 wheels short of adjusting for the additional width.
Front, I'm thinking 245/35R20, which is quite different than stock, but is about the same as 295/30R20 in terms of dimensions, I suspect these will be just fine up front, maybe even need some spacers.
Thoughts?
TTown
Tulsa, OK
'20 4Runner; '19 CRV; '06 Explorer; '17 Civic
In my humble opinion I'd suggest not getting 20" wheels. I've driven the current gen mustang with the 20" wheel options - rode like it was on rolling rocks. 30 sidewall sounds even more brutal. Definitely would never go below 35.
AZ18yote
Arizona
Bryan
Currently sitting on light weight 20Ă—10/20Ă—11 on 285/35 and 315/35 respectively with a mild drop. Ride is still smooth compared to prev vehicles I have had. As long as you are not sacrificing performance with heavier wheels it can be an option.
Jeff's FRC
Lakemoor, IL
Jeff
2020 Mustang GT
I would go 305/30 and 265/35 with those wheel sizes OP. That will keep the diameters pretty much identical front to back and those widths will work perfect for the wheels you chose.
I'm running 305/30/20 and 285/30/20 on my car and love the setup. Most 35 series tires look too big for my taste...
AZ18yote
Arizona
Bryan
I was considering going 30 once I need another set of tires due to that. How's your ride quality on the smaller profile?
ShadowS550
Chantilly, VA
2017 Mustang GT Performance Package
I have the same set up. Not stiff or bumpy at all either. Like you said, as long as you're not going with a heavier wheel, it makes no difference.
And with the 35 series tire for those widths, it's still a beefy tire. I get compliments all the time on the look and people can't tell it's a 20 inch wheel.
jenksdrummer
Jenks, OK
Slight change, went with AMR Dark Stainless; which are a bit less wide; 20x10 and 20x8.5. Tires, I'm figuring that 255/35 and 295/30; specifically Nitto or Toyo depending on if I can get a decent deal (though, I also found that Nitto = Toyo = Nitto, so not matter much)
michail71
2018 GT 401a A10
Was it fully stock suspension on the 20" package? It would probably be a little rougher on a PP car. The 20" and PP1 have similar chassis setups.
I find it a surprisingly smooth ride but my past 3 cars have been German. So it might just be what I'm used to.
jenksdrummer
Jenks, OK
Considering the ppk2 wheels are 305/30r19, I find your concerns a bit if a stretch. No offense intended, just I'm not really seeing much difference; and I admit that can be ignorance on my part.
Going to 295/30R20 is 0.1" less sidewall width, and the car will sit 0.4" higher. I figure it should be good :)
5pointOh
Jax, FL
2019 GT PP1 Ingot Silver "Millennium Falcon" @falcon_s550
I have those wheels and I went with a set of Federal 595 Evo, 255/30/20 and 285/30/20. Ride is pretty much the same as the 255/35 and 305/35 BF Goodrich Comp 2 AS but WAY better grip dry and as good grip in the rain. I got all 4 tires for less than $500 shipped off ebay.
