Do I need more negative camber?
sw686blue
Quebec, Canada
Nick
2017 Race Red Mustang GT PP
Hello folks.
My 2017 GT is lowered on BMR minimum drop springs and I'm running Forgestar F14s 20x9.5 (285/35/20) wheels/tires in the front. The tires often rub against the front fenders when I hit some bigger than normal dips on the road.
Would adding more negative camber fix this problem?
Thanks for any advice.
ModularKid21
‘15 GT
Possibly. All things considered, a 9.5” wheel is on the smaller side of things. My guess would be that it’s a combination of having not enough negative camber and using a tire that’s a bit too tall. Your wheel offset comes into play as well if you’re running a wheel where the offset is aggressive
sw686blue
sw686blue
Quebec, Canada
Nick
Offset is +56 which makes the wheels perfectly flush.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
sw686blue
sw686blue
Quebec, Canada
Nick
How do you get perfectly flush with +56 and 9.5" wide??? That would be rubbing the strut hard if it were the actual offset.
The +56 offset is more likely the rears. In any case, the fronts and rears are perfectly flush.
sw686blue
sw686blue
Quebec, Canada
Nick
