tw557
I have been involved in building motocross, roadrace bike and a few Fox body 302 motors for years. They are always normally aspirated motors and most are carburetor too. Its all about efficient cylinder filling. Cam timing, lift, duration and overlap, intake tract length, header length to exhaust scavenging. Since the piston will always have a vacuum as its trying to fill, everything needs to be done to make that as efficient as possible.
But now I'm getting interested in turbo motors. And from most of the research I'm finding, the basics of turbo power is related to consistent boost pressure, heat control, timing and quality fuel. My assumption is that at all times at any given load on the motor, the PCM is LIMITING the boost with either the wastegate or the BOV. I assume this must be true since a PCM tune only, will add boost and HP at every RPM with all the factory parts.
So back to my original question. Do hard parts really do anything at all if the PCM is there to LIMIT the boost anyway. So if you add a downpipe does the wastegate just open more to relieve more pressure. Same with the intake and BOV. No question that a Intercooler could be very helpful though.
