Different tire psi for up sizing wheel?
TheDonSalami
New Jersey
2017 Mustang Ecoboost Premium Fastback
For summer, I'm planning to go up a size from the oem 18s (235/50) to aftermarket 19s (275/40). Is it a different psi number from what's on the door panel or can I use the same with the 19s as I did with the 18s (32 psi)?
Bluemustang
2015 Mustang Base GT
I would set the psi at about 29-30. To take advantage of the additional grip of the wider tires, you need to decrease the tire pressure. At 32 psi, the size of the contact patch of the 235s and 275s will be the same, just a different shape.
samd1351
Olathe, KS
Sam
2017 Mustang GT, 1999 Ranger
If he's going from factory 18's to 19's wouldn't he better off using the psi on the tire? Your door sticker is for 19" tires, is the sticker different for 18's? Just asking, as I will hopefully be going from 19 to 20 next year.
Bluemustang
No. I would only change the tire pressure if you're going to a wider tire. The psi on the door jamb is more related to supporting the mass of the car than anything else.
samd1351
Olathe, KS
Sam
Hmm. Did not know that. Guess I learned something new today.
samd1351
Olathe, KS
Sam
I did run out and ckeck my sticker. Mine also says 32 psi. Good to know also that they offering up tips for 100 MPH and up driving :like:
