DI pump. Does it need a gasket?
HKusp
Hampton, Md.
Jason
I am assembling my built engine and looking at the DI pump which has an o-ring where it engages with the head, but there is a recession in the surface of the pump that looks like it might need a gasket. The surface of the head where the two meet is machined smooth so I am trying to figure out if there is anything else needed to seal these two together.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Did one come off with the original engine? I do know you're supposed to replace the bolts though
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
Not speaking from direct experience, but the way that o-ring seals you should not need anything additional on that surface. The o-ring will take care of it all. Also, I doubt you need to replace the studs. There would be no reason that they would be torque to yield.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Sorry, I was misremembering. It's the bracket bolt that's one time use for some reason. I agree though, since it's only sealing oil that oring should be sufficient.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
That O ring will seal the hole just fine. The bolt has red Loctite on it and it's a bit of a bitch to take off. Ford's standard shop procedure is to throw away ANY bolt that comes with Loctite pre-applied. I re-used my bolt. There was enough remaining Loctite on it as it was. No issues doing doing so.
Jaymar
Portland, OR
Jaymar
Yes, Ford says to throw away bolts that have thread locker installed but all you have to do is clean it up and reapply if you'd like.
HKusp
HKusp
Hampton, Md.
Jason
Thank you guys.
