Cruise Control Intermittent
tom_sprecher
Living Race Car Free
Marietta, GA
2016 GT Premium PP 6MT Race Red
Like the title says. At first the Cancel/Resume button was not working. Recently it would not turn on consistently after pushing the On button. Once time it was working fine and then when into Cancel mode by itself and I could not turn it off.
Any Ideas? Does any one know if there is a module for the cruise control, or where it is located, so that maybe I can check for a loose connection?
tom_sprecher
tom_sprecher
Marietta, GA
Bump
tom_sprecher
tom_sprecher
Marietta, GA
No.
Jetnoise
Raleigh NC
2018 GT Premium PP1, 70 Shaker Mach 1 stroker, 1967 F/B 357W, 1968 302 Vert, 4I 85 5.0 B&M Blower
Any changes from stock configuration?
tom_sprecher
tom_sprecher
Marietta, GA
No.
tom_sprecher
tom_sprecher
Marietta, GA
could be a clutch position sensor
Is that adjustable? I did have the master cylinder replaced under warranty about 3 months ago.
Jetnoise
Raleigh NC
Use your dead pedal?
Could be electrical or a mechanical gremlin
Any play at the top of the through?
Clutch spring been swapped?
tom_sprecher
tom_sprecher
Marietta, GA
Use the dead pedal all the time.
No play.
Steeda spring swapped over 2 years ago.
I will check the clutch sensor. When the clutch master was on its way out the pedal would not return to the top, and that prevented CC from being turned on. As soon as I pulled the pedal back up, I had full throw, and the CC could be turned on.
Jetnoise
Raleigh NC
So none of that is pertinent to the current situation?
I thought you said you had no mods from stock...
usgiorgi
Fairfax, va
C6 Z06
Yea exactly I'm positive that's his issue. The clutch position sensor is probably thinking the clutch is engaged even when it's at the top of the travel.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I think I may be having this issue too.
usgiorgi
Fairfax, va
C6 Z06
I don't remember if the Mustang's OBD PIDs track the clutch pedal position. If so, it should be easy to see what the car thinks the clutch pedal position is.
