Coyote engine swap
JungleG1337
MD
2015 Ecoboost
[MENTION=18960]Eco85[/MENTION] Thanks for making this thread. I want to do the same thing down the road when this 4cyn gave out. Did you document everything? parts list and what to lookout for? Also. did you find out if you can unlock the cap on the speedometer?
Eco85
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
Yes there will be a list , buy a programmer
Witj85
Central FL
Josh
17 Mustang GT Base 6spd in Shadow Black
If the swap comes with the ecu, bcm and abs module then only the keys need programmed?
Eco85
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
Ill post the list tonight
Eco85
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
There may be things i forgot but its late and i just worked a 16 hr shift
so just yell at me if you see something not right or got questions
Ecoboost to coyote swap list
This is not a “how to” but a list of what I used
To swap the engine in my car
Swap at your own risk
Parts from the gt I used:
Engine with complete accessory drive
Trans “pedals and shifter will be the same if you keep the trans style “
Engine harness
Under hood harness
Body harness
Dash harness
Body control module or reprogram
Powertrain control module
Radio control Module or reprogram
keys or reprogram the eco keys
Air box
Radiator, fan and hoses
A/C compressor hoses
K frame
Motor mounts
Dash cluster or reprogram
Driveshaft
Trans cross member
Exhaust
Evap line from intake to the hard line on rail
Front springs
Fuel pump
Ecoboost parts left in:
Hard A/C lines on frame rail
Abs module must reprogram or get the gt “good luck”
Accelerator pedal
Evap system
Door wiring
coolant bottle
Headliner wiring
Front suspension "except springs"
Steering Column and wheel
Power steering
Air bags and all sensors
zackmd1
Zack
You swapped the body harness as well?
Witj85
Central FL
Josh
I'm gonna try and cross reference some of the harnesses. I don't really wanna take the whole interior out
Eco85
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
There different part numbers ive looked at the harness when i had them laid out next to each other. There were a lot of things that were the same but the gt harness had a few pins that were in different spots , some wiring coloring was different as well as the gauge size mostly thru the dash. Ive said before i bet u could change just the underhood harness and reprogram the rest of the car and ill bet it would work but thats not how i did it and cant promise it will work. The wiring was easy !:thumbsup:
Eco85
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
Small update :
So the car has been running flawlessly . It came time to change the radiator to the gt rad but the eco condenser doesnt fit! So i have two solutions , 1. Get the gt condenser or 2. you can get an aftermarket thick core ecoboost rad and keep the stock eco condenser and cooling fans . Im going with option 1 since i already bought a gt radiator and fans.
TheMagneticV6
Virginia
2016 GT Performance Pack premium
Small update :
Does the remote start work as it did with your ecoboost engine? And what exhaust setup are you running with it?
Eco85
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
The ecoboost didnt have remote start but the gt did and yes it works.
TheMagneticV6
Virginia
Ok, so the ecoboost was manual when before you swapped it then? And after all was said and done, what was the exact amount of time you invested in the whole swap?
Eco85
Eco85
Mad Scientist
Northwest IN
Justin
2015 mustang
No idea , roughly 30hrs
