3.5 Ecoboost Engine Swap
DruDru_97
New Mexico
Drew
2016 Mustang Ecoboost premium
Hello there, I've been bouncing around the idea of swapping the 2.3 I4 out of my ecoboost and putting in a 3.5 v6. I know its not particularly cost effective and if I wanted more power I should've gone for the 5.0 but Im curious how doable this is.
Currently my 2.3 has a bent intake valve so I need to do some valve work to get the car back on the road, assuming the piston isnt cracked. IF the piston is cracked I'm seriously considering swapping to the 3.5 rather than rebuilding the 2.3 but I want to know if anyone has information on this.
Are the engine mounts from the 3.7 the same as the 3.5? I know the turbos and exhaust manifolds from the 3.5 fit on the 3.7 so Im curious if there are other parts that are shared between the 3.5 and the 3.7.
If the engine mounts are not the same, will the 3.7 mounts fit the 3.5?
Obviously I'd need the harness for the 3.5, the intercooler, and so on.
Any thoughts on it all?
SouthernCyclone
Georgia
Rich
2013 Mustang 3.7 TT
It’s been done on a 3.7 V6 mustang and it still wasn’t cheap.
3.7 engine is basically a bored out 3.5 like the F150 3.5 EB, but the 3.7 has port injection and few other changes engine wise.
SouthernCyclone
Georgia
Rich
2013 Mustang 3.7 TT
I’ve read the 2.0 Focus ST block is better then the 2.3 EB block. So I would probably build one of those for ease. 3.5 is going to be a lot of work and more money.
Elgyn
Vancouver, Canada
2016 ecoboost, MT, DIB, Premium, PP
That's more of a PITA than it's be worth. It's not a simple drop in, add a couple of bits, move a few things around and re-program a couple modules. It's a gut the car and start from scratch type of project. If you want more power, cubes or whatever a 5.0L swap would have a better R.O.I.
DruDru_97
DruDru_97
New Mexico
Drew
Would the 2.0 block mount the same as the 2.3?
charlesj5
Atlanta, GA
www.instagram.com
Charles
2018 Ecoboost
@DruDru_97 The Type-A 2.0 block from TunePlus would work and perform very well if you're not looking to spend $10K+ on a 5.0. I'm currently replacing my 2018 2.3 after a rod went through the bottom. Out the door from TunePlus, I ended up spending around $7K for a full assembly kit, upgraded 2.0 Type-A block, NX2 turbo kit, radium baffle plate, catch cans, oil, plugs, pulley, studs and several other items. I'm also replacing the cylinder head and manifold from Ford and that netted around $700. It all comes down to how much time and money you have. As others have said, ROI would be way better on a Coyote swap and that would of been my choice but i don't have type of cash or patience. Additionally, I think that would require a new wiring harness and fabrication items that would run more in labor than I was interested in figuring out. I'd assume a V6 3.7 would have a similar situation, but i have no idea on that. Hope this helps
Idaho2018GTPremium
Idaho
2021 Camaro ZL1 A10
Coyote Chase
Don
2010/2018 Mustang
I've been waiting for the Taurus Cop cars to start coming to auction for a similar project! And have even thought about picking up a Crown Vic to swap into my 2010 Stang!??
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
What caused it to blow? What mods did you have at the time?, Boost pressure? Power levels? Very curious as I have an 18 and wondering how much my car is in borrowed time.
Coyote Chase
Don
2010/2018 Mustang
I've talked with the guys at AutoMafia when I was racing down in Florida last year... They've developed some mods for the 3.7 with turbo chargers and have had results similar to the SHO 3.5 specs! 2011 V6 Mustangs are starting to pop up on Craig's List for under $5K...
ihasnostang
MN
www.youtube.com
Saturn ion, 2019 201A, EB PP1, Ruby Red
