z6cyl
I was originally considering the v6 as I had a 2014 v6 before, but they're hard to come by with a manual and my color choice without ordering from the factory, which is now closed for 2015.
I'm considering a 2015 EcoBoost but have some concerns.
Thoughts anybody?
- What's the boost power band feel like? - My dad has a 2011 EcoBoost F-150 and I drive it quite frequently. On acceleration from 0 its very mild for the first few moments and then suddenly boost kicks in and its quite aggressive. Is the boost power band in the EcoBoost Mustang smoother?
- What is being done about the intake valve issue on EcoBoost engines (or any DI turbo motor)? - As you guys may or may not know direct injected engines get buildup on the intake valves due to the design, after a while this buildup can cause misfires and other issues. In non turbo motors you can use intake cleaners and do other sorts of things to help prevent and clean up this build up. On turbo motors you can't as the exhaust is too hot for the turbo and chunks of the buildup can't freely go through the turbo without damaging it. The only solution Ford has so far is pulling the head and completely replacing the intake valves, not an easy or cheap job, especially after the warranty is up.
Thoughts anybody?
