Compressor Surge, Turbo Flutter
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
Now that I watched the video that IS NOT compressor surge...that is the BOV fluttering, probably due to a weak vacuum pressure source. Where did you tee the reference air for the TiAL? Should be off your fuel pressure sensor hose downstream of the solenoid.
You'll know compressor surge when it happens because your turbo sounds like its "Chuffing" or imagine a scuba regulator and the sound it makes when breathing out.
So in the first video i posted, The part where i stall up the car isnt compressor surge??
Tune+
St. Paul, MN
www.facebook.com
Adam
2015 Ecoboost Mustang Automatic
Your second video is not compressor surge, the first video is indeed surge.
Tune+
St. Paul, MN
www.facebook.com
Adam
In the first video, about halfway through when you are stalling it up and letting off. That is compressor surge 100%. You can hear the air deflecting off the compressor wheel.
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
So Adam, I'm trying my hardest not to let this thing surge. Its so hard because just barely getting on the throttle and letting off suddenly it'll do it. :/
Tune+
St. Paul, MN
www.facebook.com
Adam
Yup, that is why I recommend the BOV's I did on the previous page.
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
You said yourself there's nothing i can really do... Well shit... Not a diff BOV will fix it in place on what i have on it now?
Tune+
St. Paul, MN
www.facebook.com
Adam
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
Well damn! Nearly $250. Fuck. Lol. Guess ill have to wait a lil bit
Acristo94
Delaware
2015 Mustang Guard 5.0
storm you can get the hks that cpe has to offer
VargasTurboTech
Hayward, CA
Turbo everything
We have the same piping on our car, using a TS Race port BOV. We had noticeable surge at all light throttle, and lifting scenarios when first installed. I simply went down to a lighter spring, and the issue was gone instantly. If you are running a Tial Q, use the black spring, it will have the BOV open at idle, but that is fine, the throttle blade is closed, and the charge pipe is not under vacuum. The second you touch the throttle the BOV will close.
Black spring can be found here. http://www.atpturbo.com/mm5/merchan...tp&Product_Code=TIL-BOV-006&Category_Code=BOV
Alloy
S550 EB
So on the 1st video at the 3rd time he gives it throttle, I have a similar sounding fluttering but at low throttle and the fluttering frequency is faster. I don't hear the air deflection when mine flutters. Was this something I should be concerned about? I don't want to ignore it and have problems down the road. i am on stock piping using a TurboSmart Kompact BOV. It was the only OEM replacement out there at the time. I have it 1 full turn from soft using an Adam tune.
Tune+
St. Paul, MN
www.facebook.com
Adam
VargasTurboTech
Hayward, CA
Turbo everything
You do not need a new BOV unless you enjoy spending money. The Tial will surge on just about any car with the spring they normally include. Also what size line do you have connected to it. Tial suggests nothing smaller than a 1/4" line for a full vent, as you go down in line size, the signal is cut down the same amount, causing that delay when you lift from Positive pressure to vacuum, allowing the stalled boost to reach the compressor and attempt to stop it, spin it backwards (the flutter noise you are hearing). If the lighter spring did not fix out issue, I was just going to put the stock DV back on the car, with the BOV. Then you have the DV on the hot side to help avoid the light throttle, low throttle surging, controlled electronically by the ECU, and you will have the Tial BOV on the cold side controlled by vacuum. Either one should fix the surge. The surge with the stiff spring on our car was very very pronounced, and not something that should be ran for long periods of time.
stormtrooper
stormtrooper
Saginaw, TX
Chance
2015 Ecoboost
Its got the 6lb spring in it now. Figured that was low enough
Sent from my SM-N900P using Tapatalk
