Components for Sync 3 Conversion
Ashiq73
Southern California
2016 Mustang GT 6 Speed Magnetic Metallic
So I am thinking about converting over to the full Sync 3 System from my Base Stereo.
Parts have been popping up on ebay more and more now compared to past 6 months to a year.
I wanted to confirm/find out exactly which parts I would need for this conversion.
Here is my understanding of what is needed (might have the names wrong), please correct me if I am wrong.
- Premium Bezel
- Sync 3 Screen
- Sync 3 Computer Module (I believe this module is available either with nav or without)
- The CD Player Unit (I am not sure if my existing CD Player unit will work or if I have to get a Specific Sync 3 version)
- GPS Unit/Antenna
- Harness/Wiring
I think that is all I need but please let me know if I am missing something.
Here is what I am not sure about:
- Is HD radio included or do I need to get some other part
- Is Sat radio included or do I need to get some other part
- Is Navigation dependent on the module or screen also
If anyone has part numbers, that would be great.
Thanks
zackmd1
Zack
- Premium Bezel: Correct
- Sync 3 Screen: Correct (usually module and screen are sold together)
- Sync 3 Computer Module (I believe this module is available either with nav or without): Correct, Make sure you verify that the module came from a car with factory nav since it is very expensive to add later.
- The CD Player Unit (I am not sure if my existing CD Player unit will work or if I have to get a Specific Sync 3 version): Not exactly required, base headunit can be programmed to work with the sync module and screen. HD radio and sat radio will require a premium headhunt however.
- GPS Unit/Antenna: Antenna required for sync 3 regardless of nav or no nav.
- Harness/Wiring: Correct, you can modify your current harness to work.
- Is HD radio included or do I need to get some other part: I believe HD radio does not require any additional hardware other then the premium headunit.
- Is Sat radio included or do I need to get some other part: Additional sat radio antenna is required.
- Is Navigation dependent on the module or screen also: Nav is dependent on the sync module (APIM)
Thanks
Answers in green.
This also might be useful.
http://www.mustang6g.com/forums/showthread.php?t=31286&highlight=myford+touch
Ashiq73
Ashiq73
Southern California
Thanks Zack for the information.
One question, I just remembered, would any programming be needed?
Thanks
AlexhadanM3
Los Angeles
17 GT Blue
How much would his conversion cost ?
