Codes on my new short block
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
Well got a check engine light and got the codes. P0306, P0301, P0300. Now my remote start won't work. Engine is running fine. Damn.
CEHollier
CEHollier
Prairieville, La.
Charles
Did they swap over all of your mods? Or is it just 100% stock for now?
Swapped over all of my mods. Possible spark plug issues? Possible tune issues?
usgiorgi
Fairfax, va
C6 Z06
Those are all misfires I'd expect with a bad intake manifold runner control valve.. Not sure if there has been any reported issues from the GT350 ones though.
Do you feel any stuttering or jerkyness on very light throttle around 2k rpm?
CEHollier
CEHollier
Prairieville, La.
Charles
once or twice in 750 miles. But didn't get a code.
usgiorgi
Fairfax, va
C6 Z06
Yea it took a month or so of that behavior before I got a code. At first, I was trying to make myself believe that it was all in my head.
The dealer should be able to easily see if the valves are working as they should
CEHollier
CEHollier
Prairieville, La.
Charles
Is your manifold stock?
kenand1988
Phoenix, AZ
2020 Mustang GT
dang sorry to hear you're having some growing pains with the new short block
CEHollier
CEHollier
Prairieville, La.
Charles
If it was an IMRC valve wouldn't the cylinders be on the same side? This shows cylinders 1 and 6. Opposite sides of the motor. I would be highly suspect two IMRC valve issues. And not feeling the jerky sensation. Felt it once yesterday. That's it.
kenand1988
Phoenix, AZ
2020 Mustang GT
I say try a reinstall of the tune after a wipe.
You could always datalog it.
Lonmon
Mid East US
2018 Mustang GT 10spd Base
You may want to try a crank relearn. I got codes but no actually running issue on my 15 when I switched the clutch and flywheel and did not perform a relearn. As soon as I did the relearn everything was back to normal.
CEHollier
CEHollier
Prairieville, La.
Charles
Bingo. That was it.
Lonmon
Mid East US
Boom, your welcome! LOL! Glad its worked out.
CEHollier
CEHollier
Prairieville, La.
Charles
I'm going to give it a few more miles and then do a Lund re-tune and put those MMR gears to work. :)
