Hack
- Nov 26, 2014
- Minneapolis
- Mustang, Challenger
When I swapped transmissions I bled using the factory instructions and it worked fine. The toughest part was making up a rubber stopper to fit the master cylinder. When you pull a vacuum the air bubbles come out of the system. The vacuum helps the air rise because gasses expand with low pressure. When the gas expands the relative difference in density between the brake fluid and the gas increases. This helps the air bubbles to rise out of the system.
