Clunking sound when turning steering wheel?
jrsimon27
Outside the USA
Mustang GT 2016 PP
Has anybody encounter with this issue?
When turning the steering wheel either left or right all the way i can hear a cluncking sound coming from under the car also i feel the noise close to the accelerator pedal i checked everything and all the suspension is tight. Cant figure it out.
Thanks
UPDATE: The dealer says the left lower control arm needs to be changed cause the bushings are worn out.
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
Thanks
Do you have large aftermarket wheels? Strut clearance may be an issue.
Any other modifications? How many miles on the car?
2016 Mustang GT PP w/ Voodoo
Does it happen the first time you move the car with the wheels turned, and mainly only when its kinda cold out?
jrsimon27
jrsimon27
Outside the USA
Mustang GT 2016 PP
Nop it does it all the time cold or hot.
I turn it left and start to move the car and then it makes the clunking noise i can feel by the accelerator pedal.
Taking it to the dealer tomorrow will keep you guys updated on what they fine.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
If it was something like me, exhaust pipes might be coming in contact with the transmission mount. Not sure how that'd be happening on a stock car though.
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
If it only happenes when turning its most likely a control arm issue.
Agreed. This, or it could be loose hex screws/other steering shaft issue, wore tie rods, or some other random anomaly. Yes please OP, let us know what the dealer finds.
Fabiannn43
Los angeles
Fabian
2016 mustang gt Premium
Hey wondering why you said this and if you know the fix ? I have this exact issue. 2016 mustang gt clunking noise appears only when cold and turning to the left or right side
Yeah, they do that. It doesn’t seem to be a problem, so thats the good news. I don’t know the specific joint or part thats slipping and making the noise, but its a very common report in colder weather and comes and goes with the winter months.
if it persists after the first hard turn or so, it could be something else. The noise I’m talking about is generally only on the first turn.
GTGwen
Missouri
Gwen
I have this exact issue you described. Colder weather definitely plays a part. Mine does it when I full lock to the left (usually right after warm up). It sounds like a flat tire rolling off the rim. After about 30-45 seconds, I'll have "service advance trac" message, followed by "hill assist not available", "traction control off". I park in a parking garage (all left turns on the way out - all rights on the way in). The notifications on the dash continue until I pull out and drive straight for about 30 seconds.
It's now starting to do the noise anytime I fully lock to the left. (Backing into my garage, pulling into tight parking spots, etc.) But without notifications...
For Christmas, I purchased a lowering kit that I'm procrastinating putting on since it'll void any warranty. Should I just contact the Ford dealer?
