- Aug 8, 2016
- Pompano Beach, FL
- 2016 Mustang Q750
Full soft. We have track tested this-setup to come to this conclusion.
Steeda Tech
Steeda Tech
Hi Matti777,Steeda progressives with ProActive fixed shocks/struts, bump stops and camber plates are on the way. I hope they are a noticeable upgrade. I hear the '20 base suspension is similar to the '15-17 PP. I'm hardly an expert but I would say the base suspension is a run of the mill street suspension package. Its ok but hardly sophisticated but not horrible. The worst is the bounciness over dips in the road, bumps, etc. It doesn't feel very sporty and the car could be more responsive. We'll see if other mods are in order such as bigger front sway bar, bigger wheels and tires, cradle lock, etc.
Thanks. I should be ok but I wlll contact you if I run into any issues. I've watched some videos and installed coilovers before. Fortunately I'm fully tooled up with a 4 post lift, sliding bridge jack and a 1 ton spring compressor.Hi Matti777,
If you like, pm Steeda Tech your contact info and we will go over the install with you to make sure it is perfect once the parts arrive.
Steeda Tech
We appreciate your order Matt & glad we were able to get everything out to you!Steeda progressives with ProActive fixed shocks/struts, bump stops and camber plates are on the way. I hope they are a noticeable upgrade. I hear the '20 base suspension is similar to the '15-17 PP. I'm hardly an expert but I would say the base suspension is a run of the mill street suspension package. Its ok but hardly sophisticated but not horrible. The worst is the bounciness over dips in the road, bumps, etc. It doesn't feel very sporty and the car could be more responsive. We'll see if other mods are in order such as bigger front sway bar, bigger wheels and tires, cradle lock, etc.
