Changed tire Size, much better feel now.
Steeda-Sergio
Valdosta, Ga
Sergio
2018 Ford Mustang Ecoboost, 2016 Jeep Grand Cherokee, 2022 Suzuki GSXS 1000 GT
kz
West Chester, OH
Mustangs & F150
Previous set up:
F: 19x8.5 255/40/19
R: 20X10 305/35/20
Current new set up:
F: 19x8.5 245/35/19
R: 20x10 285/30/20
For the rear tire thats almost a 2" reduction in diameter.
The car absolutely feels more peppy. And the the throttle response is significantly better.
The down side is the wheel well gap kinda looks weird to me now. But oh well.
Of course it accelerates better - you changed effective gearing of your transmission / differential this way. Also your max speeds in each gear (including top speed of the car) are lower and cruising on the highway will be at the higher rpm if at same speed as with the previous tire.
(and speedo will be out of whack but it already was since previous one was taller than stock).
This isn't remotely small tire - I run 315/30R18 which has 25.6" diameter...
robvas
MI
2011 GT
You sure about that ? Smaller diameter, shorter gearing - not taller. Probably something like 3.73 or more (too lazy to calculate).
Very sure about it. If he has 3.31's it was like having 3.12's with the bigger tires.
robvas
MI
2011 GT
It was - with a taller tire. Now the gearing is obviously shorter - that's what I meant - may have misread your post.
You can do it either way. I think the calculator says 3.65 if you go that way
S550HPP
PDC
2022 HPP Vert
The cars sits on steeda progressive springs atm.
A part of the reason for going a bit more narrow with these tires was to mitigate some of the fling.
They're building data centers faster than McDonald's out here. For the next handful of years. Shitty part, the roads are constantly covered in dirt and gravel tracked out by the dump trucks. Sending splatter down the car. Having the tire slightly back inside has made a significant difference.
Could have gone with rock blockers. But I don't like them much.
Totally....small spacers should keep inside plus even if inside fronts will splatter qtr panels I used rock blockers while running full PPF.
SnowFox
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
Well shoot.
I think those of you who said it's too small are right. Took a long hard look again and yeah....to small.
So! Ordered a new set will be here Tuesday.
(Glad the tires had a 45 day try and drive)
