Albertcado
Just got an alignment and everything looks good except for the caster difference from left and right that I'm stumped about. The suspension is completely stock and here's the specs after alignment:
Left caster is 7.3
Right caster is 6.6
Front Toe 0
Rear Toe. 0.13 both sides
Rear Cambers: -1.5
Is that caster difference from L/R anything to be concerned about? I know I'm stuck with it since that's from the factory, but from other s550 alignment sheets I've seen their casters are usually both in the low 7 range.
Is this something I need to fix (If even possible) or will it have no negative effects on the way the car drives?
Left caster is 7.3
Right caster is 6.6
Front Toe 0
Rear Cambers: -1.5
