Car won’t start
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Looks like Ford has found the problem. This is the first time I have heard where the factory has let the dealer take the heads off.
09cs
09cs
CA
2019 GT350
Oh really?!
K4fxd
NKY
All the other Shelby engine failures I know about the dealers were told to send the engine back intact. Do not take apart. If they don't know the root cause of a common failure, the dropped valve is common, they want the engineers to take the engine apart to figure out why it failed.
Your Dad should have no worries now. Enjoy the car.
Tomster
Beware of idiots
Tom
The policy has changed. I documented a 19 GT350 engine failure where the heads were removed.
K4fxd
NKY
That means they know why they were breaking. Any new cars and replacement engines should be fixed.
I call this great news.
Tomster
Beware of idiots
Tom
They are still swapping engines. They are not being repaired.
K4fxd
NKY
You are missing the point. Whatever was causing them to break has been fixed. All new assembled engines have the correction.
If it was a bad run of springs, they are now using good springs. If it was something else that problem has been addressed.
Has nothing to do with them replacing or rebuilding engines.
Dcgtconv
Alberta
Darryl
2020 GT500KR, 2009 GT500KR, '69Mach1 SCJ, '68 Conv
Holy crap, that’s quite the surgery! Looks very organized and clinical though, glad you are close to getting out of the hospital so you can get back to enjoying the car, cheers!
Tomster
Beware of idiots
Tom
And you know this how?
K4fxd
NKY
It is corporate practice.
Epiphany
Global
I like to disassemble things.
I think Tom meant specifically, how do you know Ford made a running line change to the original spec springs?
K4fxd
NKY
That I don't know. Just using my corporate knowledge as a base.
The fact Ford is letting dealers take apart blown engines says Ford knows the root cause. If that has been fixed is an educated guess. That would come down to the bean counters.
Is it cheaper to fix the problem or eat the engines that fail. I don't know that answer.
Tomster
Beware of idiots
Tom
Ah ha! I thought so.
K4fxd
NKY
fishpick
Part of NY w/ high taxes to support the other part
0 mustangs owned currently
I'd be amazed if Ford doesn't address / update minor model year issues from year to year...
Like the brake recall - I'm sure that's changed now - as an example.
I always assumed that's why part numbers change over time - as an improvement is implemented a part number says it replaces part X.
All assumptions - but I really cant see anyone running a line year after year with a known issue in it unless its a retooling cost...
