Car shutdown completely after a run and would not crank unless jumped?
Kennysum1
Huntsville, Alabama
Kenny
2017 Alfa Romeo Quadraflio, 2018 TT GT Prem, 22 GT
So I rented out a track on Saturday to work on my suspension setup and to get the car dialed in and consistent.
The mods list is very extensive but I will name the big ones:
2018 GT Premium stock Gen 3 engine
Twin turbo Hellion sleeper kit, 62 mm ball bearing
1050x injectors on return fuel system with dual fuel pumps.
Tuned by Lund
Viking Crusader adjustable shocks all the way around
BMR Drag springs & chassis lockout
trans brake and 2 step
1500 hp rated axles
Single piece drive shaft
Transmission built out by Power by the Hour.
E-boost 2 controller
N-Gauge
The weather was perfect on Saturday and I was just trying to get a baseline run with my rear suspension set to 12/12 as a starting point. Only running on waste gate. So no massive amounts of boost.
Launched at around 2900 RPMs and had a decent run with minimal wheel hop that I let out of quickly followed by getting back into it to finish out the run. Trapped at 110 MPH on wastegate (1/8 mile).
As soon as I let out of it the car back fired and sounded like the war in Ukraine. If it was supposed to sound like that it was bad ass sounding and honestly sounded like a Lambo or something. But it had never done that before.
Then I pulled into pit lane and it just cut off. No check engine lights. No wrench, nothing. Hit the start button to see what it would do and it just acted like it had a dead battery while reading 11v. Brought another car and some cables up and hooked it up and it did crank but I shut it off as there was a distinct ticking noise now coming from the front of the engine. Did not want to damage it so I did not turn it back on.
Pulled the dipstick and no metal shavings in the oil. Oil looks and smells fine. When the car was cranked up for the 5 seconds or so it had no smoke coming from the exhaust etc.
Kind of dumb founded on where to start. With no codes and stuff I guess I will just have to pull it apart and see what is going on under the hood.
Btw does anyone know how to check the oil pressure on a 2018 with the digital cluster installed and a N-Gauge? I cannot find a gauge for it any where.
Thanks.
rabid_josh
Columbus, OH
Josh
2020 Ford Mustang GT
dont know, but hope its an easy one. doesnt sound good
BombZombie
Minnesota
Jay Adam
2017 Shelby Super Snake
A few years back, I had a 2015 WRX that on a cold January morning backfired like a machine-gun on decel, and the exhaust turned into a flamethrower. It also died as soon as I pulled it over on the shoulder. Towed it back home, and it started up again in a few hours. Smoke would then start pouring out the exhaust after a few seconds.
Later found out...my turbo blew, my catalytic converters no longer existed, and I had oil throughout my intercooler.
I hope none of that is the same as your situation.
Kennysum1
Huntsville, Alabama
Kenny
No flames and I am running 3 inch exhaust no cats/muffler. Turbos are fine and no oil in the intercooler. So luckily it does not sound like that lol
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
11v ? Maybe the alternator got smoked. That would also account for that supercar sound haha.
Kennysum1
Huntsville, Alabama
Kenny
It would also explain why it died haha. If I get that lucky I will be lucky as hell.
wazslow
PA
2016 Mustang GT/CS
Any further updates? Did the car actually run when you jump started it? You may want to post in the forced induction section as well. A lot more people will likely see it.
Kennysum1
Huntsville, Alabama
Kenny
Vert
Indiana
Whipped 19 GT Premium
Did you check the volts at the battery once you got it started to rule out the alt?
Kennysum1
Huntsville, Alabama
Kenny
Not yet. Did not get home until late.
Kennysum1
Huntsville, Alabama
Kenny
So got a little more info. Started it up and took 2 separate 1 min data logs. Going ti send them to Lund and hopefully get some information back on that.
Mechanical tear down of the top side of the engine will start this week.
