Can someone explain this to me
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Since I'm a dummy when it comes to alignments, could somebody please explain these pics to me? Thanks !
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Nope
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Other than @DonnieO you guys are just full of insight :rolleyes:
GT 550
Australia
Black GT MT S550
That rack looks like it's leaning/needs calibrated.
:crazy:
Got to be at least 5 deg of camber in that screen.
@WildHorse can you be more specific please? With 3k + posts you must know to to search. Or ask the alignment shop? It's hard to respond without knowing what the question is exactly.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
:crazy:
Basically I dont trust any shops around here. So hence I didnt ask them.. as for the pics.. which show the front tires which shows rears I noticed the left v right are diff settings.. seem the right front toe was out ? Thanks.
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
The photos with castor in the 6s covers the front tires. If the first two photos you posted are the “after alignment” settings, then you’re fine.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
I have to agree - it took me a bit to figure out what the display was trying to tell me with icons that words would have conveyed with immediate comprehension. Especially for the 'front' vs 'rear' indication, little pictures aren't always the best way. It helped a lot that I had some idea going in as to where numbers for the various parameters should fall. Shouldn't have to look at all the little pictures and the numbers to figure out what's going on
It also appears that the top two pictures were the 'after' measurements and the bottom two were the 'before'.
Right vs left measurements typically do differ slightly, particularly where adjustment capability neither exists as OE nor added later. A couple hundredths of a degree or so difference in toe normally doesn't matter and is probably within the physical tolerance of making those adjustments.
Norm
jwt
Alberta
2019 Ford Mustang Bullitt
[QUOTE=" A couple hundredths of a degree or so difference in toe normally doesn't matter[/QUOTE]
And is within tolerance of the tire tread, rubber bushings, flex in suspension components etc etc. No harm in getting it as close as possible but no point stressing about it either :)
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Thank you gentlemen !!
