Can’t get a Gen 2 long block replacement??
MHW100
Nanaimo
Matthew
2017 GT350 gen 2
Is it true that you can no longer get a Gen 2 replacement long block from Ford?
My understanding from the dealer is that they aren’t manufacturing these any longer so they just rebuild the failed Gen 1 or 2 engines.
Seems wrong since the last model year was only 2020.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Buddy’s engine went at Cota two weeks ago and the dealer is installing a new engine right now. So assume they still have some.
MHW100
MHW100
Nanaimo
Matthew
2017 GT350 gen 2
Good to know. My replacement was built dec 21 or Jan 22 (can’t remember)decoded from the engine plate so hopefully I’m done with replacements. I did note they didn’t change the original builder’s names on the engine when itwas replaced. They just used the 2017 stamped plate that was on the cover.
WItoTX
Houston
Kyle
'17 GT350
My understanding is there is a warehouse full of motors somewhere. So you are still getting a new motor, at least until those 5 year warranties run out. I am sure the bean counters at Ford calculated how many they need to keep on hand. And it's likely 20% too low. But who really knows...
526 HRSE
California
2017 GT350 Grabber Blue
Why would you not want to rebuild the original? Matching block numbers?
MHW100
MHW100
Nanaimo
Matthew
2017 GT350 gen 2
For one reason if the gen 1 was replaced with gen 2 the value of the pre-2019 are higher. Can’t imagine a numbers matching car would matter this few number of years since the end of production…maybe different for the more limited run of R cars.
526 HRSE
California
That's just because of the internet. If you plan on selling the car soon, that may be the case, but in the long run, matching numbers will be preferred.
MHW100
MHW100
Nanaimo
Matthew
2017 GT350 gen 2
Long run yes. Right now they sell for more on autotrader.
sk47
North Eastern TN
Jeff
Hello; nothing wrong with rebuilding a damaged engine. Sometimes cannot be done. Bad luck I suppose if matching numbers matter. If such is a big deal to someone it should still be early enough to buy a used car with an original engine.
526 HRSE
California
I think that has more to do with the internet rumors than anything else. If you believe the internet rumors, none of us should even own a voodoo because they will all explode in due time.
