CAI vs K&N drop in
Canadian Crimson
New Brunswick, Canada
Scott
2018 GT Convertible PP1 Royal Crimson
Is a CAI worth the money as opposed to just dropping in a high flow K&N filter? Many say the stock airbox flows plenty of air. There will be a catback exhaust and possibly headers in the future, but that will be in. No plans on any forced induction set ups.
Gfswindle
Huntsville, Alabama
Gary
2019 GT A10
2018-2020, maybe 2021 factory boxes flow as good as most all aftermarket CAI's. Drop in a green filter or K&N equivalent and the intake won't hold back as much power as you want to make on N/A. The one exception to this rule is a PMAS intake with a fender well kit to draw in cooler air. Otherwise most aftermarket boxes suck in hotter under hood air unless it's a closed type box. But then the MAF housings vary quite a bit due to manufacturing tolerances. According to Lund, the most consistent aftermarket intake is the PMAS for MAF curves which means their manufacturing tolerances are very tight.
2022 Mach 1
Brentwood ca
Cameron
2022 Mach 1...2014 Mustag GT whipple supercharger
Get a nice drop in filter. The gains people see from a cai are mostly tune related. CAI, DEVICE, and TUNE is a pricy investment for such little gains. Traction improvements will yield better results, actully make your car faster, and cost less.
Canadian Crimson
Canadian Crimson
Scott
Actually suspension is my first project, Steeda sprigs and the rear lockout kit. Since she is a 'vert there isnt much else to do to the rear.
2022 Mach 1
Brentwood ca
Cameron
Convertible jacking rails can add some stiffening as well. Have fun with your build, I'm sure you'll enjoy either way.
AZ18yote
Arizona
Bryan
Drop in filter and call it a day. Flows well and keeps iats down. Unless it were a 15-17 car, then would suggest upgrading to 18+ oem.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
The 18+ airbox does for sure. I switched to that and a drop-in K&N for my NA 17 GT and it was quicker/faster than my previous PMAS. NOT bad mouthing PMAS by any means, it's just in my particular setup, that was the case.
