Burnt Valve
smann
Toronto
2016 GT PP
I think I may have a burnt valve..
Did a compression test and numbers are OK.
What should I do? Full out replace the head? I think its only passenger.
Jay-rod427
Kansas
2016 GT C/S
I'd confirm the problem before I did anything else.
Torinate
Ontario
2016 GT Convertible
Ouch!
How do you know this is the issue? What are the symptoms? Wonder if a boroscope through the spark plug hole would show anything if you could turn it to see the valves?
18 Smoke
Columbus, OH
18 Mustang GT PP1 400a
Unfortunately, compression test doesn’t always reveal the issue. Run an actual leak down test on it. If there’s problems with the pistons or valves, it will bleed off and you’ll need to pull the head anyway
Tommy V
Brookly park Md
Tommy
Usually when you have burnt or bent/broken.valves looking at your vaccum can tell u alot.
schmeky
West Monroe Louisiana
David
2018 Mustang GT, 2024 Mustang GT
18 smoke is right. Do a leak down, this will help determine where it is before you start taking things apart. Unless something went lean, modern valves don't fail very often like they did years ago.
gimmie11s
SoCal
Murica!
My guess is busted ring land over burnt valve.
Need more info OP.
smann
smann
Toronto
2016 GT PP
Let me do a leakdown and I will keep you guys posted.. I thought it was my rings as well but my mechanic confirmed to me that it is not.
When he put the car back together I started having the issue again and he said only thing left is burnt valve.
smann
smann
Toronto
2016 GT PP
Is there an upgrade I can perform to the head? I might as well spend a couple hundred dollars mode and get an upgraded version
Or is there anything that'll bolt right on.. I know the GT350 heads are an option but you need to get the cam, etc.
smann
smann
Toronto
2016 GT PP
Update:
Lost 3 cylinders, 1,3 and 4
compression 30-50
The rest are healthy. It was in fact the rings, my previous mechanic fucked me over. Put the car back together with a SERIOUS oil leak and while I was driving the car leaked all the oil.
Not enough lubrication, mechanic went AWOL.
No longer replying to my msgs, picking up calls, and is not there anymore because he knows my shortblock is fucked.
18 Smoke
Columbus, OH
Update:
compression 30-50
Man, that sucks. I know it’s not cheap, but go with a reputable builder and get it done right. Good luck!
Tommy V
Brookly park Md
Tommy
Did u see the car leaking oil after u got it back?Im wondering why he thinks all the oil leaked out.
engineermike
La
2018 GTPP A10
Why did the original compression check ok, then later was only 30-50 psi on three cyls?
Tommy V
Brookly park Md
Tommy
I think u need to find a new mechanic,i think.the guy you are using is clueless.
smann
smann
Toronto
2016 GT PP
I found a new mechanic, my original mechanic did most of the installs on my car. My car was leaking but he said it was from oil in and around the engine bay stuck in the plastic trms slowly dripping down.. All I could do was believe him, I checked the dipstick and it looked OK then I drove 1.5 hr back to my area and I think most the oil came out.
Really it was my valve covers not on properly/sealed which is why ALL my oil seeped out when I gave it some gas.
Car was pushing so much oil out when I lifted my hood the black cloth thing thats attached to the hood was DRENCHED in oil. Like so much that I put a microfiber on it and pressed it and the microfiber was soaked as well.
Compression test was originally OK, i think this all happened because of the lack of oil in my car. Only coming from the issue of the install being done incorrectly.
I took it to another shop they said the same thing, huge gap between valve cover and all the oil was coming out from there.
