Bump Stop Question
Edgemere
Minnesota
Edge
2022 Mustang GT Premium
Greetings,
I installed the Ford Performance Track Pack shocks and struts with the Steeda minimum drop linear springs, Front 200 lbs - Rear 800 lbs and their pre-cut bump stops. I like the suspension, however going over more pronounced bumps it sounds and feels like the rear shocks bottom out. In talking with Steeda before the purchase, they told me their pre-cut bump stops are perfect with their min drop springs and the FP Track Pack shocks and struts. Is what I am hearing and feeling when going over bumps,are the springs hitting the bump stops? Are they too long? And, if so, should they be cut back? How easy is it to do it now? I did not do the work myself. I had a qualified suspension shop do it. They said the bump stops where correct at install time. Please advise.
Thanks in advance!
shogun32
Northern VA
put the car on a 4-wheel lift. grab a tape measure and see how much free travel you have. The dirt-protector will be in the way but you can get it accurate to about 1/4" by pressing on stuff with your fingers to feel where the bits are.
Eibach spring bumpers are the answer.
Also if you really are hitting the bump stops, take a thin zip-tie (the ones that are like 2mm wide) and put it on the shaft a good 1/2" above the bump stop. Make sure it's pretty tight. Then go do your driving around where you think you're bottoming out. Put it back on the 4-wheel and feel around for the zip tie if it's been 'homed' to the top.
