Bullitt tuning issue vortech
Rockford
Joe
19 Bullitt
Hoping maybe someone has an idea what could be going on. My installer is having difficulty tuning my 2019 Bullitt. Basically they are having overfueling by almost 60%. They cant get correct AFR at idle. If they pull the maf tables by 60% it cleans up somewhat. It's a beefcake stage 2 V3 kit. It include the gt350 throttle body adapter plate and intake tube, ID1050x injectors, bap, and standard 3.6 pulley. They are in the process of swapping injector to rule out faulty injectors.
Mechanical timing, vacuum leak, and bap have been double checked. Next is getting a different tuning file.
My question is can the gt350 throttle body or gt350 intake manifold in the bullitt be causing tuning issues? The shop does many centri coyote jobs. They have never had this issue before.
Thanks.
andrewtac
TX
mark
F250. 2020 GT 400A
Could be the throttle body, was told on the gt350 intake to use the stock tb (2020 car), with Lund.
cbrtrx
tampa fl
2016 mustang gt
The gt350 t.b. or manifold should not cause any fueling issues.
Jackson1320
California
Jaxson
2015 mustang gt
Isn’t the 87mm t.b stock on the bullet. Sounds like maf data or injector data. You can dial in both. Should not be a problem
Mustang_Lou
Toronto, Canada
2020 Mustang Bullitt
Maybe the tuner isn't aware of the TB differences on the Bullitt??
